Loud VibrationNoise
Old Oct 6, 2007 | 07:06 AM
evo_rc's Avatar
Loud VibrationNoise
I'm hearing a loud vibration noise from my car. It sounds like a metal chain being drag into the ground, loud chattering noise.It seems like it only happens after driving around when the fluid is warm. I can hear it during idle and also when I press the clutch in and drive. The noise is loud enough and it comes and go. I currently have act clutch and fidenza flywheel.Could it be my throw out bearing or input shaft? my lj boot on my rear driveshaft is currently blown, I will replace it next week. Can it also be my driveshaft? If anyone has an idea I would appreciate it.
Old Oct 6, 2007 | 09:58 AM
tdz16's Avatar
Most likely if you are getting noise when the clutch is in and when it is out, then it is not the throwout. Does it get more harsh sounding when you press the clutch in?
Driveshaft carrier bearings and CV joints would only give you noise in motion for the most part.
Is the noise RPM dependant?
Old Oct 6, 2007 | 12:52 PM
evo_rc's Avatar
Not really, even being on neutral on a drive thru it would come on and off. It seems like it only happens when the fluids are hot. There is no change in sounds when I press the clutch in, I realease the clutch and it is still happening? Could it be my input shaft? I'm doing a tranny flush next week, If I have metal shavings what can I conclude from that. Thanks
Old Oct 6, 2007 | 03:47 PM
evo_rc's Avatar
Nevrtmind fixed it...my 02 sensor was loose.
Old Oct 6, 2007 | 03:57 PM
tdz16's Avatar
Clutch feels ok?
I would take a really good look around underneath the car and make sure nothing is loose first to rule out anything peripheral. I've heard of catalytic converters making some noise at times when they are shot. How many miles you have?
~Tom
P.S. - When you drop the trans fluid look at the larger pieces that come out, they will tell you most of what is going on inside the trans. A chip of a gear here, a detent ball there, all that fun stuff....
Old Oct 6, 2007 | 03:59 PM
tdz16's Avatar
Haha, definitely seemed like something loose from your desc. Congrats!
~Tom
Old Oct 10, 2007 | 09:11 PM
evo_rc's Avatar
Thx, yea the sound is gone...
smokedmustang
37
Sep 8, 2011 12:37 PM
blownevo
32
May 30, 2009 08:16 AM
WillH19
20
Sep 19, 2008 12:58 PM
mrpeeper
Lancer Tranny/Drivetrain Tech
27
Jul 28, 2008 04:19 AM
