Toluence
Old Oct 6, 2007 | 05:26 PM
Mirage2.0's Avatar
Toluence
Propably this has been talked about but is anybody using Toluene. I have read some great results on other forums. I know you can buy this in Home Depot, Lowe's or other paint stores.
Here is my question: Which one to buy? I just want to be 100% sure before I put it a gallon or two in my tank.
Here is what I found:
http://store.hamiltonmarine.com/browse.cfm/4,5722.htm
http://www.jamestowndistributors.com...4031&YAHOOSHOP
http://www.pleasureboatmarine.com/rec83274.html
Can someone post a pic of what I need? Thanks in advance.
Old Oct 6, 2007 | 06:00 PM
Mirage2.0's Avatar
Off topic: Please move this to tech guides. Thanks.
Old Oct 6, 2007 | 06:15 PM
[EVO]Cookie's Avatar
I buy it from a paint store when I use it and I buy it in 5 gallon can at $6 a gallon.
Old Oct 6, 2007 | 06:16 PM
Mirage2.0's Avatar
OK, but I need a pic or approval. Read my post.
Old Oct 6, 2007 | 06:20 PM
Buy the cheapest one if it's 100 percent virgin solvent that's all that matters.
Old Oct 6, 2007 | 06:26 PM
fryedchikin's Avatar
Toluene is Toluene, it really doesn't matter what the packaging looks like.
Old Oct 6, 2007 | 06:38 PM
Mirage2.0's Avatar
I just want to make sure that I'm getting the right stuff. Thanks guys.
So any of these above are any good?
Old Oct 6, 2007 | 06:43 PM
There all good, the prices are high.
Old Oct 6, 2007 | 07:32 PM
Mirage2.0's Avatar
Thanks.
How many gallons you use per full tank. I thought of using 2 gallons.
Old Oct 6, 2007 | 07:43 PM
It depends how much you want to raise the Octane of whatever gas you are using.
This is the formula to calculate your final octane rating
( Gallons_of_gas * Octane_of_gas ) + ( Gallons_of_toluene * 114 ) / Total Gallons
You might find some more helpful information in this thread https://www.evolutionm.net/forums/sh...hlight=toluene
Old Oct 12, 2007 | 12:00 PM
Asmodeus6's Avatar
20% mixture on average
Use the highest available octane at the pump for the best results.
I have used it as a buffer for the track on multiple occassions. Pour it in, THEN add fuel. It takes a while to circulate. Drive it a little before you expect an even mix.
I normally leave my tune alone and slowly push up the boost.
Or leave my boost alone and slowly push up my timing.
Its not a very big buffer.
Don't expect magic.
I have seen a 93+tol @ 30% mix take on a 34psi 60-1 setup with a 12.5/1 A/F and an aggressive timing swell for spool.
But your milege may vary.
Old Oct 23, 2007 | 01:50 PM
TouringBubble's Avatar
I checked on some toluene yesterday at the local Sherwin Williams ... $16+/gal after tax. where could I find it cheaper? I've heard mention of $2.50/gal at it's lowest, but that was with a 55 gal drum purchase. I'm hoping to pay around $5 - $6 per gal.
Old Oct 23, 2007 | 03:28 PM
Plan on buying a 5 gallon can It's high for just a gallon. The Sherwin Williams around here sell it for $40 for a 5 gallon can. Any paint store that sells Lacquer thinner should be able to get it for you. It is a controlled substance.
Old Oct 24, 2007 | 11:40 AM
I'll check on a 5 gal container. Thanks.
Old Oct 27, 2007 | 07:58 AM
Slo_crx1's Avatar
Also try not to buy large quantities each time you go to the paint store or they start to get suspicious. Toluene is one of the bases for making crystal meth, and I had the cops knocking on my door after me and a friend went to Sherwin Williams and bought a few of their 5 gallon cans lol.
