Forged High Compression Pistons in 4g63T do able ? and worth while ?
Old Oct 12, 2007 | 11:42 AM
Evo8Emperor's Avatar
I was wondering if you could go with higher compression forged pistons in a stock 2.0 block to make some added power with out having to stroke it ? Or i should say can you do that or is there more to it ?
Old Oct 12, 2007 | 01:08 PM
mchuang's Avatar
For the 1 compression point that you raise the hp is minimal compared to the extra boost threshold allowed by 1 point of lowered compression.
Old Oct 12, 2007 | 01:46 PM
SLVROZ_03's Avatar
Plus, the lower compression allows for more room for error when it comes to tuning...
Old Oct 12, 2007 | 01:53 PM
mchuang's Avatar
That is kinda part of what I said lol also horsepower from 1psi of boost > 1 compression point
Old Oct 12, 2007 | 01:58 PM
stig's_mentor's Avatar
my 2 cents
i think there is pro's and cons to high and low comp.
yes low comp you can run more boost with the loss of power, BUT if you can run lets say 2.3 bar on a high comp engine, would you really wanna run more boost than this?
when does a specific turbo run out of efficiency?
i know alot of guy's who run around 1.95 bar on high comp engines here in the uk.
ultimately speak to your tuner. he will advise you on what is best for your goals.
personally i have 2 different engines, 1 with 9.0 comp ratio, the other is 7.5 comp
low comp engine gives me more torque, but this aint on my evo. off boost its lazy, but its a race engine, so never off boost
Old Oct 12, 2007 | 02:57 PM
Asmodeus6's Avatar
Higher compression is not for the faint of heart. A person with a setup that doesn't change often that has the resources to get a very good tune will appreciate the higher compression motor especially on the street, d/d situations where the car sees a wide rpm range. The way a higher compression engine comes up can be nice. Assuming the setup and tune follows suit.
Old Oct 12, 2007 | 05:49 PM
VRSF Tiago's Avatar
You better be a great tuner with a higher compression ratio. If you are gonna do it I'd reccommend upgraded rods as well so you don't end up bending a rod due to knock.
With the cost of new pistons and rods, a stroker kit is a coupel hundred away anyway.
Old Oct 12, 2007 | 06:44 PM
mchuang's Avatar
You will more than likely kill a bearing before bending a rod, rod bending normally comes from water ingestion. On a side note, bottom line is you will only gain a slight bit power on a high compression motor vs low compression motor, but you can easily make up that minimal gain with 1 or 2 psi of boost. 2 psi of boost can get you 20 - 30 hp and 1 compression point wont do that. Plus the ability to handle knock will be better.
Old Oct 12, 2007 | 08:22 PM
Asmodeus6's Avatar
Fuel, makes a large difference as well.
A 10-1 motor on race gas isn't so scary.
Well, it is, just not how you're thinking it is.
stayer
10
May 23, 2017 09:38 PM
94AWDcoupe
Oct 21, 2016 08:41 AM
konstantinosIX
20
Oct 26, 2008 06:09 PM
ROCK
Feb 22, 2006 10:13 AM
HOK
17
Feb 4, 2002 03:57 PM
