code P0505
Old Oct 16, 2007 | 03:16 AM
augosta's Avatar
code P0505
Hi every one
After installing TBE , air intake, MBC 22psi, fuel pump, and a mail tune I am having CEL with code P0505 IAC Motor Circuit Malfunction
What could be the cause and how to solve it?
Thanks
Old Oct 16, 2007 | 03:22 AM
augosta's Avatar
Notice that I have EGR on my car, can the ideal valve be dirty from the EGR
Old Oct 16, 2007 | 04:18 AM
gsrboi80's Avatar
Did you run a boost leak test. Somtimes my car throws a code after the test
Old Oct 16, 2007 | 04:43 AM
augosta's Avatar
In this country we don’t have boost leak test
Old Oct 16, 2007 | 05:22 AM
Whoop_ass's Avatar
I have gotten the same error,
only started when i installed my cosworth cams!
bump for you
Old Oct 21, 2007 | 04:06 PM
kkarim's Avatar
Try adjusting your idle an extra 200-400rpm higher using the small screw on the TB. That made it work for me, two weeks without the fault already!
Old Oct 21, 2007 | 04:13 PM
Psquared's Avatar
Its not a test someone else does....(well maybe) but a test you do yourself to make sure you aren't leaking any air from intercooler piping or other places. If you search on the forums here, there is a "how to" on how to do a boost leak test on your car.
Old Oct 21, 2007 | 04:22 PM
gsrboi80's Avatar
BEISSEN
Feb 17, 2015 06:53 PM
05VIII
10
Jan 12, 2011 06:38 PM
KY
Jul 26, 2010 07:23 PM
GiGas
Oct 1, 2009 02:27 PM
KOTT
Sep 17, 2008 08:59 AM
