Best Buschur mod...new bullet muffler with a Magnaflow
Old Dec 22, 2008 | 08:11 AM
  #31
jxs1984's Avatar
Originally Posted by Jrod@Buschur
There is one muffler in the place of cat / off-road pipe. The other is in the rear of the car.
He is confused as he does NOT have to lose the rear muffler. I ran a JDM rear bumper with the 2 bullets.
See here:
does the tip look angled or is it straight out?
Old Dec 22, 2008 | 08:47 AM
  #32
Jrod@Buschur's Avatar
The one on my car had a slight angle too it. We can straight cut them also.
Old Dec 22, 2008 | 08:53 AM
  #33
jxs1984's Avatar
awesome. any sound clips of the bullet/bullet or bullet/magnaflow?
Old Dec 22, 2008 | 09:04 AM
  #34
Shacochis06's Avatar
Yes you can purchase whatever combination of our exhaust you would like and swap things in and out as needed.
Many people will buy the system with the highflow cat then purchase the bullet muffler to swap out.
What about if you have a diffrent tbe already and wanna swap to your v-band?....what all needs to be done?...i dont feel like buying anothe 1000 dollar exhaust
Old Dec 22, 2008 | 09:06 AM
  #35
Here is a full out pass of my car with 2 bullet mufflers.
http://videos.streetfire.net/video/J...ing_143385.htm
Old Dec 22, 2008 | 09:10 AM
  #36
I dont understand what you're asking.
Are you already running our V-band system or.....?
Old Dec 22, 2008 | 09:12 AM
  #37
sending you a pm
Old Dec 22, 2008 | 05:14 PM
  #38
90GSXDan's Avatar
How much would this cost for someone that already has a full buschur TBE with no cat?
Seeing as Im in New York, I really dont have the money nor time to go all the way to Ohio.
Im looking for a decent sounding exhaust thats not too loud.
Thanks!
Dan
Old Dec 22, 2008 | 05:16 PM
  #39
David Buschur's Avatar
90gsxdan, what are you looking for exactly and one of us can quote the price.
Thank you.
Old Dec 22, 2008 | 06:10 PM
  #40
BluEVOIX's Avatar
Thanks!
Dan
First I believe you need to understand how they have their car configured to run 2 mufflers. The bullet mufflers are located at 2 locations, the first muffler is at the test pipe location and the other muffler is at the rear section behind the bumper.
You want to know if its possible to make your current buschur exhaust system run 2 mufflers and how much it will be.
I am going to assume you currently have the bullet muffler at the rear. If I am correct, then you dont need to change your exhaust system and Buschur might be able to offer you the muffler option that installs in place of your test pipe. Just let them know which exhaust style you have.
Old Dec 22, 2008 | 06:54 PM
  #41
Levar's Avatar
Veteran: Army
This is a nice thread but I'm just the opposite as I've been looking to run the BR race muffler with a test pipe combination. I was told that there is really "hardly" any difference sound-wise between the BR race and BR bullet mufflers. Is this true? JRod, do the BR race mufflers still sell for $225-250? Thanks.
Old Dec 22, 2008 | 07:07 PM
  #42
SloRice's Avatar
I would say there is very little difference between the two mufflers. vwjeff's car and my car are equally loud!
Old Dec 23, 2008 | 12:22 AM
  #43
SpeeDeviL's Avatar
Okay I got the BR TBE with test pipes, and bullet muffler, so all I need it an additional bullet muffler and place it at the test pipes location, right??
Also am running stock ECU and the O2 sensor is on the test pipe, so where can I install the O2 sensor when I get the other bullet muffler???
Old Dec 23, 2008 | 05:24 AM
  #44
SloRice's Avatar
My midpipe has the O2 sensor bung, not my test pipe.
Yes, all you need to do buy the bullet muffler setup to replace the test pipe. I just did this a few months ago with my car when I put on the JDM rear bumper.
Old Dec 23, 2008 | 05:39 AM
  #45
kmcconn9's Avatar
Well I can attest that two BR Bullet mufflers is very quite under normal driving conditions, but quite loud under WOT.
When I put my car on the dyno after getting the second muffler installed, there was no loss in hp or tq.....none. The muffler just flows that well.
Just call Buschur, ask them to weld you up a Bullet muffler to go where your test pipe normally goes. Put the 2 bolt flanges on either end, and your set...
