Huge boost leak!
Old Oct 17, 2007 | 04:01 PM
Erik@MIL.SPEC's Avatar
If you can't hear the leak, that means it's probably a HOLE, like a vacuum hose or something similar.
Old Oct 17, 2007 | 04:19 PM
PorkRoll's Avatar
ok i have the cover off of the cam gears. i see the marks however the marks do not line up the same on both cam gears. I bought my car used could the car be camed? stock, shouldnt the markings line up the same?
Old Oct 17, 2007 | 04:21 PM
PorkRoll's Avatar
also the sound i should here will be high pitched most likly unles a vac house is off right? I have the tester on the uicp only now and it is still not holding pressure. i think the throttle body might be leaking bad.
Old Oct 17, 2007 | 04:30 PM
RazorLab's Avatar
The marks should line up no matter what it has, cams, gears set at -12/+12, whatever.
Old Oct 17, 2007 | 07:09 PM
C6C6CH3vo's Avatar
Just line up the intake cam so all valves are closed (either use the mark or have any cyl at highest point) . The air volume with an air compressor ain't enough to close the PVCCV so pop that hose off and plug the intake manifold side. If your pressurizing from the MAF pipe you must also make sure the hose from that goes to the rocker cover is also plugged or else the air will leak through the sump out the dipstick. One more line to plug if not already (MBC) and thats the WG solenoid vacuum line. Just apply about 5 psi and it should hold for a minute or so.
Old Oct 17, 2007 | 08:07 PM
mplspilot's Avatar
Originally Posted by mplspilot
Either you unplugged some vacuum hose, or if you have mbc, you did not plug the turbo hose that goes to it (usually on the bottom).
i have a mbc and the hoses are on. The egr valve is ok. all i can build the pressure to is 5 psi. the exhaust is plugged the oil fill cap is off and no air is comming out of there. i still dont hear the leak nut it obviouslt there some where. this is so fustrating.
What i meant was the turbo hose that goes to mbc needs to be taken off and plugged shut with like a phillips screwdriver. Otherwise your mbc will be leaking air when you try to pressurize everything.
Old Oct 18, 2007 | 11:05 AM
wreckleford's Avatar
Instead of listening for leaks, fill a spray bottle with soapy water and spray it on all the joints, hose connections, throttle body shaft etc. The soap will bubblle up wherever you have a leak. You will be surprised how many leaks you find that you could not hear.
Old Oct 18, 2007 | 12:04 PM
AlwaysinBoost's Avatar
try wetting your hand and reaching around your engine bay, IC piping & intake manifold at the same time while you are filling the system with air and see if you can FEEL the air hitting your wet hand. Sometimes big leaks are very quiet because the air is coming out as fast as you can put it in.
I had a hose pop off the back of the manifold and it took me a week to find it until I figured out this little trick.
Old Oct 18, 2007 | 01:33 PM
mplspilot's Avatar
Originally Posted by AlwaysinBoost
try wetting your hand and reaching around ..
sorry couldn't help it!
MisUnderStood
Jun 28, 2017 10:20 AM
Evolution7GSR
Jun 16, 2016 02:57 PM
commbubba19
May 9, 2016 08:15 PM
vr4gasmtt
Jun 14, 2015 10:12 PM
MitsuJDM
11
Dec 28, 2010 02:14 PM
