Smoke on left turns only?
Old Jan 23, 2014 | 06:06 PM
555R's Avatar
Do you mean the line to the pcv? I replaced it with a new one and it still smokes
Originally Posted by mrfred
oil pouring into the intake via the crankcase breather line?
Old Jan 23, 2014 | 09:30 PM
mrfred's Avatar
sorry, i was confused. the pcv side would be the culprit. i have been told by those who have experience that the head fills up with quite a bit of oil at wot. if you let off on the gas in a lefthander after extended wot, it might be possible to suck oil into the intake manifold thru the pcv valve. if that is the issue, the solution is a catch can, kiggly hla, or both.
Old Jan 23, 2014 | 11:51 PM
ItalianEvo's Avatar
Oil level too high.
In hard left turns, oil goes all to the right, been catched by the crankshaft, thrown on cylinder wall and then it passes through the rings as in first part of the turn you're in vacuum
Old Jan 25, 2014 | 08:20 AM
555R's Avatar
Well my oil level is at the factory capacity. I replaced the Pcv itself but there wasn't any oil in the hose or valve itself. It still smokes on left turns. I'm hoping my rings aren't shot but it's just odd that it only smokes on left turns. Annoying as hell.
Old Mar 9, 2014 | 10:10 AM
555R's Avatar
Still looking for a solution. The while Pcv system is unplugged. It still smokes. I'm hoping it's not a ring issue.
W0LF
17
Sep 1, 2017 12:40 PM
D1andonlyantman
20
Jul 2, 2014 10:47 PM
Slobwalker
Oct 2, 2013 12:41 PM
mr 2.3 evo
17
Nov 14, 2011 09:21 PM
