Please help with engine noise...
Old Oct 19, 2007 | 12:01 PM
dodgecoltracer's Avatar
Unhappy Please help with engine noise...
Well the noise started a little while ago, at first I thought it was my lifters but I think it has gotten worse
I'm completly stock. Fluids (including trans, differential, ect) changed about 3 weeks ago. Spark plugs changed about 2 months ago with a new O2 sensor. I over reved once merging with traffic on 195, stupid bus.
Waiting to hear the bad news, thanks for any advice!
DodgeColtRacer
[IMG][/IMG]
http://s221.photobucket.com/albums/d...t=MVI_2664.flv
[IMG][/IMG]
http://s221.photobucket.com/albums/d...t=MVI_2666.flv
Old Oct 19, 2007 | 05:05 PM
anyone.... please.....
Old Oct 19, 2007 | 05:40 PM
Kerr's Avatar
Fomer Vendor
Sounds like the injectors.
Old Oct 19, 2007 | 06:54 PM
1killertsi's Avatar
does it go away when clutch is pressed? the second vid sounds like my car, the famous throw-out bearing noise.
Old Oct 19, 2007 | 07:51 PM
scottatyamaha's Avatar
Well as the weather gets colder your engine oil gets thicker and that will make your lifter tick louder because it is harder for them to get pumped up. You could even have a completly bad lifter also. But you also said that you overrevved which could mean bent valves.
Old Oct 19, 2007 | 09:02 PM
jrsimon27's Avatar
first video could be a lifter or an injector and second video sound like the TOB
but you should make a compression test also just to be sure,how many miles does your engine have?
Old Oct 19, 2007 | 09:46 PM
it has 51k, 30 from the previous owner, and 21 from me. thank you for your advice! TOB huh, should I not drive it until it gets fixed? I'm gunna call the dealer tomorrow and get an apointment asap. really tho, thank you guys!
Old Oct 19, 2007 | 11:52 PM
Mike.p's Avatar
what did you rev your car out to when you "over rev'd"
Old Oct 20, 2007 | 03:07 PM
hit the rev limiter, I beleive stock is around 7600
Old Oct 20, 2007 | 03:17 PM
evo_man_06's Avatar
lifter i think
it really sounds like a lifter
Old Oct 20, 2007 | 10:12 PM
Thanks for the input guys, much appreciated
Old Oct 20, 2007 | 10:18 PM
bhamEVOguy's Avatar
if u hit the rev limiter, then u didn't really over rev. thats what the rev limiter is there for, so u cant over rev. i doubt over revving had anything to do with that caz i hit the rev limiter plenty of times and i've over revved without doing any damage. maybe i was just lucky there and i dont plan on over revving ever again unless i get my motor rebuilt. and by over revving i mean going *past* 8500rpms
turbodav
15
May 28, 2009 12:09 PM
Lancerguy'03
North Texas Evo Club (NTEC)
22
Mar 5, 2009 12:13 PM
ilive2win
63
Sep 25, 2008 05:23 AM
blackdemon
May 13, 2007 04:28 PM
cbrtrx
Oct 3, 2006 07:46 PM
