Limiting factor in setting boost?
Old Oct 24, 2007 | 11:34 AM
72Tornado's Avatar
So this is a fairly stupid question, I know...but what are the limiting factors (besides the completely obvious) in terms of how high you can set boost? Obviously octane rating is key, as is how much the bottom end can handle...but what prevents someone with an MBC, TBE and tune from being able to safely run 23-24psi? Or is that safe?
Old Oct 24, 2007 | 01:23 PM
dan628's Avatar
The stock turbo can only handle so much, most people do around 21
Old Oct 24, 2007 | 01:47 PM
mplspilot's Avatar
My stock turbo handled 28 psi peak. Knock is your factor.
Old Oct 24, 2007 | 04:38 PM
kreionic's Avatar
Exactly detonation is your problem not strength. Stock turbo is no where near the limits of strength with your motor. I dont run e85 like the post above me but on pump I run 25ish psi and 29-30 with c12
Old Oct 24, 2007 | 05:19 PM
Sluggo's Avatar
23 - 24 psi is relatively safe for an ix, generally speaking. when cranking up boost knock is the limiting factor, and eventually the efficiency range of the turbo comes into play.
Old Oct 24, 2007 | 06:23 PM
LoCo4's Avatar
I remember reading here that at 26 psi the stock head studs start to stretch.
Old Oct 24, 2007 | 07:25 PM
EvoJoeIX's Avatar
i have not found an actual case where this has happend, im not saying it hasnt, but i havent found any hard evidence on it yet.... anyone have any?
the rod bolts will most likely go before the head bolts do.....
Old Oct 25, 2007 | 09:04 AM
mplspilot's Avatar
Well you better erase it from your mind, because boost does not "stretch head studs" (they are actually stock bolts) . It's a pretty retarded misconception. Just like "backpressure creates torque"...
Old Oct 25, 2007 | 09:15 AM
Sti THIS's Avatar
20-21 is safe becuase our cars run so rich from factory. but you can prob do 24-25 safely with a tuner that knows what they are doing. Stock head bolts will not stretch due to excessive amounts of boost, but rather detonation. so if you are no where near any knock, your fine
Old Oct 25, 2007 | 09:16 AM
RoadSpike's Avatar
Two factors that limit boost:
1) Octane rating IE KNOCK
2) The amount of stress you rods and pistons can take
Old Oct 25, 2007 | 09:23 AM
belizelittle39439's Avatar
It's like a bunch of parrots are in here...
Old Oct 25, 2007 | 11:07 AM
Erik@JNZtuning's Avatar
Knock ends up encompassing almost all of the limiting factors when it comes to boost level. Except when you near the actual area where you reach the HP limit of physical components.
Old Oct 25, 2007 | 01:30 PM
LoCo4's Avatar
I was just stating what I read here.....
