Quick Cam install & Tune Question
Old Nov 2, 2007 | 08:35 AM
Twitch's Avatar
Gonna have some 272 cams installed.
1. Do I need larger injectors or are the stockers fine?
2. I have to drive the car about 20 miles after the cams are installed to get it on the dyno for the tune is that ok if I drive like a grandma?
Thanks for the help.
Old Nov 2, 2007 | 08:42 AM
mifesto's Avatar
its more personal preference if u have stock (boost levels? race gas? meth?)
ill tell you MY personal mod path.... once my cams go in, ill start running mix 50% 93/c16 and i'll step up the injectors only one step maybe
Old Nov 2, 2007 | 08:46 AM
Twitch's Avatar
Mifesto??? Wrong post I think
Old Nov 2, 2007 | 09:05 AM
Dead-Man Inc's Avatar
you wont be hurting anything, just drive normal and avoid revin high till u get tuned.
Old Nov 2, 2007 | 09:10 AM
Twitch's Avatar
Do I need larger injectors with 272's?
Old Nov 2, 2007 | 09:16 AM
Waz996's Avatar
since u goin for a tune after the cams.. why dont u get the bigger injectors anyway?
Old Nov 2, 2007 | 09:21 AM
Twitch's Avatar
Just the cost issue right now. Considering the E85 tune. So not real sure of every thing I'm gonna do yet. CAMs for sure. Doing the clutch at the same time too so my car budget is blown for the month. Just want to mnake sure that I will not have any fuel issues on the stock injectors with the 272's... Should I be ok?
Old Nov 2, 2007 | 09:35 AM
Mad_SB's Avatar
I think you will atleast need an upgraded pump.
Old Nov 2, 2007 | 09:44 AM
Twitch's Avatar
I have the upgraded pump already... Just wondering if I need larger than stock injectors to run 272's. I do have an AFC as well...
Old Nov 2, 2007 | 09:53 AM
evocanival's Avatar
Just like what '' mad_VIII" stated, you will definatley need an upgraded fuel pump. There only about 80-95 bucks shipped! This is necessary for you, if you want a tou run a lil leaner, and have bit more agressive tune. Plus, it is cheap
Second, is no you will NOT need to up-grade you injectors. I have been running 272 on my car for about 18,000 miles with the 272's on on stock injectors. If you choose too, then do so, but is isn't necessary!
Third is i drove from my staion in mid New Jersey to Conneticut without a reflash for the cam up-grade since my tunner works up there. As previously stated, dont get on your car, and rev it. Just take it easy on your way there and you will be fine! Hope this helps!
Jovan
Old Nov 2, 2007 | 09:55 AM
evocanival's Avatar
^ Sorry, should have looked in your signature to realize you got a pump already!
My bad lol.
Jovan
Old Nov 2, 2007 | 10:00 AM
Twitch's Avatar
Perfect. Thanks for the advise. The shop trys to sell me everything when I go in there. I just want to get the tune and leave. Thanks again...
benIX
May 25, 2016 10:10 AM
spinner85
Dec 25, 2014 08:32 PM
JaYr_EvO9
Oct 22, 2013 04:35 PM
binhtran
16
Apr 17, 2008 11:36 AM
PorkRoll
10
Oct 27, 2007 06:24 PM
