oem piston hp capability?
Old Nov 6, 2007 | 01:50 PM
Aby@MIL.SPEC's Avatar
how much power can the evo oem pistons/piston pins handle with a proper tune, rpm <8,500?
i know buschur & ams; among others, have made some serious power with their turbo kits & stuff.....is there a power limit for the oem pistons/piston pins before cracking/failure due to load?
Old Nov 6, 2007 | 02:07 PM
drano7823's Avatar
bump....good question
Old Nov 6, 2007 | 08:04 PM
Burklow's Avatar
Around 500-550WHP. More power = less reliability though. I'd start swapping stock internals for something stronger after 450 WHP if you want something bulletproof to drive.
Old Nov 7, 2007 | 04:49 PM
evo L's Avatar
ive seen many many many 400-450 stock block street driven set ups.
Old Nov 7, 2007 | 04:52 PM
EvoDan2004's Avatar
im on a twin scroll 30r setup. andhave reved up to 8400rpm at the drag strip. bone stock block. 11.2 126mph. and doring the day i beet the snot out of my car.
i say it comes down to how well the car is tuned and how you take care of your car
Old Nov 12, 2007 | 09:40 PM
JDMCT9MR's Avatar
This is good to know.
Old Nov 13, 2007 | 07:00 AM
supersal's Avatar
I have also been wondering about this coz I get conflicting feedback...
Some say to make 400HP+ and high Torque on like even a Green you need Head studs and Rodbolts coz they are not strong enough...
And others say if your car is tuned properly and you have minimal det then you don't need them... unless you wana boost 30psi...
Old Nov 13, 2007 | 07:22 AM
sekula's Avatar
Like said before, and from many cars I know, motors will begin to weaken after 450whp and constant beating...so if you have 450whp or more I'd recommend building the motor up at least a little to have little more reliability!
Old Nov 13, 2007 | 07:47 AM
Jeff_Jeske's Avatar
I think spinning the motor over 8000k with stock block is a tad dangerous. There have been many reports of rods letting go at high RPM.
Don't get me wrong, with the ****ty EVO9 gearing I would love to spin the motor to 8k but I don't want to poke a rod through the block at 116mph.
Old Nov 13, 2007 | 07:48 AM
hopper's Avatar
I would say the rod bolts are the weaklink. Not the pistons.
Old Nov 13, 2007 | 08:11 AM
joeracer321's Avatar
Top of #2 piston in my motor went out @ 521 WHP. But it could have lasted longer if I wasn't relying on a single 255 Walbro; the motor went lean and detonated...
Abacus
11
Nov 14, 2016 03:35 PM
4g63girl
Oct 11, 2016 02:46 PM
real fast
Sep 8, 2014 06:51 PM
06mr775
12
Aug 9, 2014 11:40 AM
Jackson Machine
Nov 21, 2010 08:22 PM
