cold weather boost!!!
God is not interested in preventing or monitoring knock. You need to do that yourself at high boost so it wise to datalog when working the evo to get power, even better - SES light patch. I agree with you, 11.1 was probably rich enough by pulling power to safe levels
I am at 4600 ft in Oregon and its cold today but sunny....i drove my car for the first time in 3 weeks. The car is tuned at 24 psi. Will it be bad for the car if i set the same boost? It was tuned at sea level and brought up here. Only a summer car so i usually dont drive it too much. Dont boost too much either but today i had to for a tiny bit
. Let me know.
. Let me know.
. Let me know.
. Let me know.I am at 4600 ft in Oregon and its cold today but sunny....i drove my car for the first time in 3 weeks. The car is tuned at 24 psi. Will it be bad for the car if i set the same boost? It was tuned at sea level and brought up here. Only a summer car so i usually dont drive it too much. Dont boost too much either but today i had to for a tiny bit
. Let me know.
. Let me know.
. Its like putting on a condom and pulling out before you blow your load. Extra safe
.I know i can bump it up to 26 or so but i dont want to go all out all the time and pump gas tune at 24 psi is good enough for me......its just a DD.
Otherwise if you keep it at 24psi, it'll be more like 22psi at sea level..
Thanks again for all you help guys. I love this community
i was told by a good tuner that if i see more boost then usual in cold weather i dont have to turn the boost down couse an ecu wiil add more fuel and pull timing and my turbo spikes to 26psi in those conditions,just watch your knock sensor,if you see service engine flashing (if you have that option) go ease on a throttle
unless i am wrong?
I don't even have a boost controller on my car right now but I'm hitting 20-22 psi with just TBE and then at about 5500 rpm the boost drops to about 8-12 psi and sometimes even 2psi. what is this and how do I fix it? My turbo still sounds like its spooling but I'm not going anywhere.
theres no wrong or right answer here, every tune and every car is different. simply if its cold weather, boost will increase. the safer/conservative your tune/car is at, the less chance a boost spike will cause issues. simple idea, yes?
griffeyr
36
Dec 22, 2008 02:21 PM
tsitalon1
Mar 12, 2008 08:12 AM
