Front A/C fan removal?
Old Nov 8, 2007 | 11:19 PM
cal1mr's Avatar
If I have removed my ac could I conclude that I dont need the front fan? Will this unplugged clip trigger a cel? I think I could get away with this considering the ac core is gone and I plan on adding some heat shielding around the o2 housing.
My plan is to use the CBRD rad w/ slimline fan and remove the front fan (also start running water wetter - are the added cooling claims legit?). Let me know if I need to rethink this.
Old Nov 9, 2007 | 07:13 PM
cal1mr's Avatar
Wow, nobody? What about those running the half size mini radiators out there?
Old Nov 12, 2007 | 10:25 AM
cal1mr's Avatar
No one with a mini radiator, huh?
Old Nov 12, 2007 | 12:00 PM
dudical26's Avatar
I have my AC and AC fan out. Still on stock rad and stock rad fan. No problems here.
Old Nov 12, 2007 | 12:20 PM
cal1mr's Avatar
Thanks. Did you just unplug the front fan and tie them down?
Old Nov 12, 2007 | 12:43 PM
Soon2BEVO's Avatar
I took out just the AC Fan. There is no CEL and you dont even need the fan if you have the A/C. I used it for two summers and it was still very cold and engine temps never rose.
Old Nov 12, 2007 | 12:55 PM
dudical26's Avatar
Soon2BEVO - sorry to go off topic here but are you going to be getting another evo any time soon?
Old Nov 12, 2007 | 01:07 PM
Soon2BEVO's Avatar
I dont know about soon but someday.
Old Nov 12, 2007 | 01:22 PM
cal1mr's Avatar
Thanks again
Old Nov 12, 2007 | 01:25 PM
dudical26's Avatar
While we are on the topic of fan removal. I have heard some people say that you don't even need your main radiator fan. Has anyone tried this?
I think I might try it soon, other than watching the temp gauge to see if it goes higher than normal, is there anything else I should be aware off? I guess I can log coolant temps with EvoScan.
Old Nov 12, 2007 | 01:29 PM
Evo8Emperor's Avatar
A little off topic but either of you running the half size radiator ? I had a idea of instead of putting it on the drivers side what if you were to keep it on the passenger's side. This way you could do custom intercooler piping which would require a new intercooler set up but it could be worth it. It all depends on how much thicker a half size radiator is.
Old Nov 12, 2007 | 01:48 PM
dudical26's Avatar
Seems like a lot of work for very little gain. I would just use a proven setup that Buschur or AMS sells.
Alchem1st
Mar 15, 2022 08:47 AM
Spythere
Jul 5, 2016 03:09 AM
dbouch
Nov 15, 2015 04:41 PM
utggevox
Jun 10, 2012 04:30 PM
gzzza8181
Lancer Aftermarket Forced Induction Tech
10
Dec 29, 2008 09:08 PM
