Problem With A Mod
Old Nov 10, 2007 | 12:33 PM
Nfazio's Avatar
Problem With A Mod
Ok this is an ongoing process and im just stumped as to how to fix it.....
I installed Injen upper and lower intercooler hard pipeing.
http://www.lancershop.com/customer/p...2&cat=2&page=1
All tubes are secure with no boost leaks.
The problem im having is a dump in my power when im running the car hard and i hit 4k rpm's in third fourth or fifth gear. The car jerks foward then resumes driving but i lose a great deal of momentum.. Also this is making my check engine light come on. Also the boost is running at a peak of 20 psi, is this not good for a stock turbo.. As of right now i have no boost controller hooked up. should i hook it up and try to turn down the boost?
Im stumped and just thinking about putting the stock parts back in and giving up on them unless someone knows how to help me.....
Thanks
Old Nov 10, 2007 | 12:36 PM
suekie's Avatar
check that your spark plugs are gapped right. So the tubes are secure, but did you really do a boost leak test, or are you just saying that? Do you have both plastic rivets on your air intake snorkel?
timmiii's Avatar
Sounds like fuel cut, what other mods do you have on the car? Also you might want to get the CEL scanned so you'll know what kind of code it's throwing.
Old Nov 10, 2007 | 12:48 PM
Nfazio's Avatar
got the engine light checked and it came up as a wastegate code.
Nfazio's Avatar
did not do a boost leak test but checked all the tubes and there all on tight and secure
Old Nov 10, 2007 | 12:51 PM
Nfazio's Avatar
The only other mod i have on the car is a cat back exhaust
Old Nov 10, 2007 | 12:52 PM
Genesis8's Avatar
Check vaccum lines?
Old Nov 10, 2007 | 12:59 PM
timmiii's Avatar
so it peakes at 20 and how far does it drop off when you feel the car jerk foward?
Old Nov 10, 2007 | 01:05 PM
Nfazio's Avatar
drops off to around 10 11 psi but if i stay on the gas it will jump back up to 15-17 before i shift to next gear
Old Nov 10, 2007 | 01:09 PM
timmiii's Avatar
What RPMs is this happening at?
Old Nov 10, 2007 | 01:11 PM
Genesis8's Avatar
He said 4k
Old Nov 10, 2007 | 01:15 PM
timmiii's Avatar
Originally Posted by Genesis8
He said 4k
He also says it jumps back up while in the same gear...
Old Nov 10, 2007 | 01:30 PM
Nfazio's Avatar
The dump in my power happens right at 4k but if i stay on the gas to about 5k rpms it will bring the boost back up around 14-17
Old Nov 10, 2007 | 01:34 PM
jmartinez1170's Avatar
I had the same problem when i got mine in 04. I got a hks edis and a retune.
Old Nov 10, 2007 | 01:38 PM
Nfazio's Avatar
What is the hks edis.
