?'s about O-ringing head/block
Old Nov 10, 2007 | 01:48 PM
PATRICK B.'s Avatar
Just wondering what the tolerance should be in the gaps of the actual ring ends when in the block or head?
Is there a diff if using copper vs alum.......block vs head.
We just got back a head for our 2G DSM and notice that there are gaps but some have larger gaps then others
Probably doesn't matter as the pressure applied when torquing i'm assuming will close the small gaps or am i wrong...........
Also do most people re-ring when removing a head whether it be a head ring or block ring?
Thanks
Old Nov 10, 2007 | 01:49 PM
EvoDan2004's Avatar
what dose o ringing a block do and why do you do it?????
Old Nov 10, 2007 | 02:03 PM
PATRICK B.'s Avatar
Helps to seal the combustion chamber when running high amounts of boost pressure
cerevo
12
Sep 9, 2016 03:45 AM
5LEEPERISAH23I
31
Nov 20, 2013 08:39 PM
sean-EVO4-nz
Aug 24, 2011 10:47 PM
Nasty Evolution
14
Oct 13, 2008 04:26 PM
blackevo110
14
Dec 13, 2007 10:52 PM
