2.4l 4g63
2.4l 4g63
For those of you running the 2.4l on a 63 block, when you built yours (if you did it yourself, i guess would be ideal...lol) what did you file your ring gaps to? I have mine loose for the most part. and wanted to see what others run. in addition to that what have you done to the head and what turbo did you pick?
but i've never heard of a 2.4 stroker.
i never paid attention to the 4g64 stuff, i have a billet crank it very well could be machined to the same specs as a stock 4g64 crank.
http://www.briancrower.com/view.php?pn=BC0108
The Brian Crower crank is 102mm, whereas a 100mm crank (typically 4G64 OEM) is used for 2.3 and 2.4 strokers. IIRC, there were some rod clearance issues with the 102mm crank out of the box.
I'm not quite following if you're building a 2.3 stroker (4g63 block with 4g64 crank), or a 2.1 or 2.4 stroker (4g63 head, 4g64 block and crank), but regardless you should have gotten specs with the piston and ring set from the manufacturer. If not, you can contact the piston manufacturer and get their recommendations for your setup. Once you get into these setups, what's stock is irrelevant.
I honestly don't remember my ring gaps. I'll look and see if I still have the literature from Wiseco for my pistons.
i think you mis-understood me. i got off the shelf JE ring sets, i just want to know what ring gaps y'all are running. its just a curiosity question. it really doesnt do much for me i built the motor in october and finished the install last month. ive just had a timing issue since. i just want to know if anyone else did a 'loose is fast' build like me. which when you think about it means...opps i shaved too much off.
evo+supra
30
May 15, 2014 11:52 PM
diablo2184
49
Aug 19, 2010 06:48 PM
ZyBeR
66
Oct 28, 2005 09:45 AM
2001, 24, 24l, 4g63, 4g64, block, chevrolegs, crank, crankshaft, dodge, engine, lamborfeeties, meth, stratus, stroker
