cams and smog
cams and smog
im looking into camshafts for my evo8. what should i get to keep my car passing smog or will it not make a huge difference when i go to smog the car? but i also do what a significant power gain.
There are quite a few im sure. I actually just answered a Q like this, but it was in Colorado. Does CA require you to do a tailpipe test like you were doing an OBD I car? Most states just plug the emissions machine into the cars ECU and turn the key to the on position and read the ECU. As long as your not throwing any codes you should pass, but if they do a tailpipe test than the cams could screw you up. When you need to do emissions you could just put the stock exhaust and converter on and that might clean up the air enough to pass.
Or you could do that, but the states have been sending agents out quite a bit to watch emission stations. There really no repercussion to you if you do it, but the tech gets fined a hefty amount and hence the 400 dollars. I had to do this once with my 240 and it cost me 175 bucks.
Nelson999
Aug 24, 2011 11:36 PM
