HTA35R drivablity
Old Nov 21, 2007 | 12:33 PM
crcain's Avatar
Originally Posted by mplspilot
Why not just reference the 3rd gear?
I think 4th gear is most common but I could be wrong.
Old Nov 21, 2007 | 01:18 PM
mplspilot's Avatar
It might be for the dyno, but not really for road tuning.. And a lot of people compare and do road tuning.. I'm interested to know driveability of HTA35r as well, and dyno pulls in 4th - i dunno how good they would reflect that...
Old Nov 21, 2007 | 01:34 PM
LT1runner's Avatar
Drivablity is just fine. I have no problems in any area of driving this car with the HTA 35R. If you get this turbo, I suggest you get 1000cc injtrs as well. You won't be sorry.
Old Nov 21, 2007 | 02:37 PM
Invoice EVO's Avatar
Veteran: Air Force
If I were to make a daily driving vid from the cockpit of my car showing RPM's and boost, what would you guys like to see? i.e. 3rd gear pull, 4th gear pull, drive through at McDonald's, just let me know and I try and help out as much as possible before the snow hits.
I would not be able to post it here as it would be on the streets.
Old Nov 21, 2007 | 02:44 PM
crcain's Avatar
You have an AEM dude.. post a datalog of a 4th gear pull.
Old Nov 21, 2007 | 04:08 PM
mmp52's Avatar
ok u guys still r not giting it how dose it respond between shifts the 3065 is instant i meen no hasatation like driving a supercharged car after u get going though the gears if anything it responds faster then stock dose th hta35r do this to
Old Nov 21, 2007 | 04:23 PM
LT1runner's Avatar
Well the stock turbo doesn't feel like the boost comes on like a supercharger. So I dought the 3065 does. The HTA doesn't feel instant either, but when it starts to build boost, it builds it FAST.
Old Nov 21, 2007 | 04:47 PM
mmp52's Avatar
ok between shifts 2nd to 3rd its preaty much instant it fells like i have a cobra again. ya if i punch it in 3rd @ 3k it takes it till 4.5k to get spooled but when i shift from 2nd to 3rd boost is right there the stock turbo even took a split second to get boost back. if im going to lose that then the hta is not an option.
Old Nov 22, 2007 | 11:49 AM
LT1runner's Avatar
In-between shifts the boost is right there with my HTA. Not like my Vortech S-trim, but as far as turbos go, it's still in the boost.
Old Nov 22, 2007 | 10:59 PM
mmp52's Avatar
Thanks LT1 sorry for being unclear on what i ment at first should have asked like that to start with. i wouldnt think it felt like a 5.7lt supercharged car what all u got in that thing any ways?
Old Nov 22, 2007 | 11:08 PM
JordanS4's Avatar
Originally Posted by crcain
calm down buddy. if you had any idea what you're talking about then you'd know making 2 bar at that rpm with a gt35r is pretty damn good. please do me a favor and find me any gt35r car making that boost that early.
most gt35's spool right around 5700 on the stock 2.0 liter in 3rd gear. 4500 in 4th with a 2.4 is not impressive, at all.
Old Nov 23, 2007 | 12:46 AM
ecuflasher's Avatar
I'd bet .63 A/R GT35R versus .63 A/R HTA GT35R there probably is not more than a 100 rpm in it. Maybe 200.
If this is true, won't those running the 0.63 housings be wasting money if they are to 'upgrade' to the HTA? How about those currently having the Buschur GT35R kit with cast manifold? Reckon they will get the same documented gains upgrading to the HTA?
Old Nov 23, 2007 | 04:13 AM
wspy's Avatar
This is a good question!
Old Nov 23, 2007 | 05:39 AM
LT1runner's Avatar
Built 355, built tranny, 12bolt rearend. I did the SQ S-Trim blower. Got it maxed out as far as blower RPMs to make 550 to the wheels. Instead of moving up to a T-trim or bigger, I figured I just go turbo. So I ropped the 355 and built a 383. I have a bigger air to water intercooler. I'm starting out with a T-76 turbo. May move up to a T-80. Not sure. T-76s are easily able to produce 1000hp on with these motors, but I may just keep it mild. Around 750 to the wheels for fun. It's be a pump gas daily driver like my evo. I'll throw some slicks on it and hit the track. It should be fun. It's almost finish. Just have to wire up the fuel control and finish the piping for the water tank for the intercooler.
When I bring it to the racer spot, I'll say it has a cam, K&N filter, and a flowmaster muffler
Old Nov 23, 2007 | 06:41 AM
dubbleugly01's Avatar
yes, this is very much true, and there are several threads about the spoolup difference of the HTA vs. the standard 35R. crcrain didn't have the same positive results that dave b. had, hence the debate.
