starting problem
im currently going through the same thing. But mine seems like the battery is dead. Really Groggy startup, but wont stay on. Only stays on if i have the stock ecu in. My PFC it will start for about 2 revolutions then die. Then wont start again. Found my Nesei Mini Batt. was dead, changed it and still the same problem. Checked alternator and is good. so that leaves me with the starter.
Seems to be like the power is not going through. Like trying to start a car that has a really dead battery. 1 slow revolution, and all lights go dim. All fuses good, all wires and guages are good. No stray wires.
Gota be the starter??
anything new?
Where is your meth soleniod in relation to your nozzle? If your soleniod is higher than your nozzle this could be allowing meth to leak into your intake via gravity and vaccum upon start thus causing a hard start up...
my evo wont start but has power i did leave my trunk open with mini battery and though was dead but wasnt cause still had enough power for lights and sff but when i try to start my car the gauges come on but nothing else happen like it wont click or anything. so would this be the starter?
yah i have the same problem right now too! my started would make a funny *** noise like the grinding of the teeth and then 2 days ago it finally went out when i tried to go home after work. so i got the starter for 200 bucks cuz the stealership seems to be the only place that has it and im going to install it tomorrow. im trying to find a "how to" to install the starter but cant seem to find one, ppl have told me its hella easy tho
Ended up being the cable wires were to small, and could not hold the voltage needed to start the car. And before that my Nesei Batt died. didnt even have for a year.(4.5 mnths) Problem flixed, relocated to trunk.
Ok im having the same problem when i start my car it sounds like a subaru then i rev it will slowly go back to normal its really strange
i see you changed the cables but im on stock battery and ecu. I have new plugs i took out the fuel pump and checked it . let me know what i can check cause it very annoying.
car is stock with the exception of a LICP, and DP.
FS[Pacific NW]: 2005 Evolution MR Time Attack Build
Jhurley_EvoVIII
For Sale - Cars For Sale
Dec 12, 2016 09:53 AM
kpt6
Aug 15, 2015 08:08 PM
High_PSI
May 6, 2015 06:18 AM
