Going for 900whp this Week!!! Pics Inside!!!
Old Dec 2, 2007 | 10:38 PM
  #196
MANGOOK's Avatar
Mike good luck reaching your goal! I hope you reach it. Also all of USP is in this thread. What's up Chris Green and CWill?
Old Dec 3, 2007 | 05:10 AM
  #197
crcain's Avatar
Originally Posted by 03whitegsr
... about the GT35R only spooling 500 slower and this turbo not making the power, you should realize that a well setup GT4294R will get to 30 psi around 5500 RPM too.
It appears you know what your talking about, so I appreciate that. But I'm sorry in 4th gear Dave Buschur said 30 psi for a 35R on a 2 litre is about 5200 rpm.
So now your saying a GT42 spools 300 rpm later!
I think I give up in talking to people about lag. 95% of the people saying this and that have never looked at a datalog in their life. I give up.
Old Dec 3, 2007 | 05:19 AM
  #198
JVELA's Avatar
I doubt that you can see full boost(40psi) on a s372 before 6500 rpm. Not to say 7000!!!
Old Dec 3, 2007 | 05:56 AM
  #199
Jasil's Avatar
Agreed.
Old Dec 3, 2007 | 07:56 AM
  #200
alpha's Avatar
Typically see 30lbs with a GT4294R on a 2.0 by 5800RPM and 40lbs by 6600RPM with a divided Full-Race exhaust manifold and 4" downpipe
Old Dec 3, 2007 | 08:24 AM
  #201
crcain's Avatar
That is impressive. What gear is that in?
Might I ask what you think a 37R sees 30 psi then?
Old Dec 3, 2007 | 08:39 AM
  #202
nos51's Avatar
Originally Posted by USP Motorsports
well it doesnt make 900 on 28 psi.. so i am sure when i on 45psi it will be over 1000rpm later spool than a 35r.. however if the powerband carries to redline and doesnt drop off like a 35r ill sacrifice the 1000rpm of course..
In my experience with making a car go fast its not peak WHP its the entire band.. My old setup had 3000 rpm of 650+whp powerband.. a car that makes 650whp from 8000-8500rpm goes nowhere.. trust me i have raced cars making the exact same power as mine but my band was 3000rpm on 37r and theirs 500rpm on a 40r and i put a bus length on them..
yea i can vouch for that......
Old Dec 3, 2007 | 08:48 AM
  #203
alpha's Avatar
That's in fourth gear
I dont have logs of our T3/T67 P trim (37R) on this laptop. I will check the other laptop in a little while for you (leaving for a remote tune). Difference is it's open turbine inlet and on a 3" downpipe
Old Dec 3, 2007 | 08:07 PM
  #204
AWD Motorsports's Avatar
so far 750whp and ripping loose on the dyno.. Im on MH DOT's and tried 3 different air pressure and 3rd and 4th gear pulls.. going to switch to a street tire and make more pulls..boost is coming in violent.. i have in car video of boost gauge and tach.. stay tuned..
Old Dec 3, 2007 | 08:15 PM
  #205
Paul Nelson's Avatar
I did 8 straps on mine wand just reef the hell out of them
Old Dec 3, 2007 | 08:37 PM
  #206
CWiLL's Avatar
we def getting 47psi before 7000rpm try early 6s lol what a monster. we put my stock evo wheels on the car now, here we go, 50 + soon
Old Dec 3, 2007 | 08:41 PM
  #207
scheides's Avatar
EvoM Moderator
Dropp the pressure in the tires really low, to like 5psi. strap it down SUPER tight, then pump pressure back into the tires. This should help!
Old Dec 3, 2007 | 08:43 PM
  #208
CWiLL's Avatar
we hazed the tires bad. the slick now
Old Dec 3, 2007 | 09:05 PM
  #209
Dam stop spraying that NOS!
Old Dec 3, 2007 | 09:56 PM
  #210
CWiLL's Avatar
thats what it seems like the min it hits over 40psi its rips the slicks like a fwd car. its bad. were working on it as we speak
