confused about fluidampr
you take off the front passenger wheel, undertray and the the cover in front of the crank pulley, pull back serpentine tensioner and hold it then there should be 4 bolts on the crank pulley that u have to take off. from there, its just swapping it and doing everything backwards to put it back together. real simple.
If you plan on staying pretty much stock than no. If you plan on revving higher than 8500rpms i would say yes. This also meets nhra requirements if you run a certain speed.
if you change any of the internals to anything other than factory made parts, you will need a damper like the fluidampr. the stock crank pulley is only made to damp the torsional vibrations of the stock internals. fluidampr will make your build last a lot longer also
when you say you love the fluidampr, did you have it installed when the motor is still stock internal?
STM Tuned
31
Feb 9, 2016 06:12 AM
CORZA
Jun 19, 2015 09:28 AM
reddragun3
Evo X How Tos / Installations
May 6, 2011 09:26 AM
