what are restrictor pills?
Old Nov 28, 2007 | 07:48 AM
moardak's Avatar
As far as I know the restrictor pill in the clutch line slows down the movement of the hydraulic fluid. This causes the clutch to engage slower. Mitsu did this to save stress on the drive train during a launch by making you burn your clutch more when you pop it.
Old Nov 28, 2007 | 08:36 AM
06MRV8Killer's Avatar
Originally Posted by 06MRV8Killer
In the OP can someone answer his question about the clutch line restictor pil and answer it in detail. For example its purpose, what it does being in and what it does being out of the car. Its ill effects if any on the car, and its advantages.....
Bump, Can someone WHO KNOWS please answer this. I am not looking for "I think this is what it is and I think that this is what happens when you take it out or leave it."
Thanks
Old Nov 28, 2007 | 08:38 AM
Thanks now that makes sense. So basically removing it would be ok, however if you launch like $hit or bang through the gears you can kill your drive train or kill it faster than normal. Is this right?
Old Nov 28, 2007 | 10:26 AM
RalliArtEvoVIII's Avatar
opposite of viagra
Old Nov 28, 2007 | 10:49 AM
Originally Posted by RedLanEVO
ok, i've tried searching for titles and havent found anything. like my title says, what are restrictor pills? i know stock evos have them...but what are they and what is their purpose? everyone seems to know what they are for since i can't find anything by searching. so, would someone please tell what they are and what their purpose is?
i know for sure i don't have one in my car anymore since all the vacuum lines were changed when i did my intake. is that bad? do you really need it?
and another question...is there a similar thing in the clutch line? i recall reading something about that too but can't find that thread anymore.
take it out, you boost more. the pills are just restrictors hence their name: restrictor pills
Old Nov 28, 2007 | 11:43 AM
moardak's Avatar
Yep. I imagine taking it out is also a great way to void your drivetrain warranty, assuming a dealer ever finds out you did it. So if you did take it out and you for instance... blew your tranny.. make sure you put it back in before taking it to the dealership.
Old Nov 28, 2007 | 12:04 PM
evo8426's Avatar
i have one of the restrictor pills removed and the boost spikes up to 23 or 24 and hold at 20-21 in every gear
Old Nov 28, 2007 | 03:59 PM
BluEVOIX's Avatar
Do you have a wideband? What a/f ratios are you running and what mods do you have?
Old Nov 28, 2007 | 05:26 PM
Not worried about the warranty a friend of mine works for mitsu and would warranty anything that breaks on the car. Fourtunately I havent broken anything yet
Old Nov 28, 2007 | 06:57 PM
evo8426's Avatar
i do not have a wideband but the ecu has been flashed other than that my car is stock
Old Nov 28, 2007 | 08:40 PM
BluEVOIX's Avatar
Interesting... May I ask how much whp & wtq your putting?
Also if you have baseline numbers to compare to that will be great.
(I'm just trying to get an idea of the gain in power a completely stock car can make with only a flash)
Old Nov 29, 2007 | 05:19 AM
gsrboi80's Avatar
You'll gain about 25 WHP on a bone stock IX with a flash
Old Nov 29, 2007 | 02:23 PM
evo8426's Avatar
i could give you evoscan whp numbers from stock map and then the current map if thats what you want
Old Nov 29, 2007 | 05:48 PM
BluEVOIX's Avatar
That would be nice. Thank you.
Old Nov 30, 2007 | 07:49 AM
xxNosTankxx's Avatar
to the OP...
As restrictor pill is what its name says. It's a pill in the line somewhere that causes some form of restriction. The one in the BCS keep you running the spicified amoutn of boost. Don't F with that. If you get a MBC or EBC then the new solenoid will replace it. You some form of restriction to keep the turbo from over boosting.
The restrictor pill in the clutch line slows the movement of the clutch fluid so the clutch engages more smoothly. Many people who go with an aftermarket clucth also get a stainless steel clutch line which has no restrictor pill. This makes for a more harsh engagement but gives you better pedal feel. Some claim it makes it easier to launch and so on.
If your drivetrain is stock and yoiu want better clutch feel, get a SS clutch line. If you need to bring it to the dealer for something then just switch the old line back in.
I just switched my MR to a 5spd Shep tranny with a carbonetic twin and SS clutchline. My drivetrain is smooother than butter. The pedal feel is incredible. I love the new setup.
