what are restrictor pills?
Old Nov 30, 2007 | 06:35 PM
  #31
sparky's Avatar
Originally Posted by xxNosTankxx
...It's a pill in the line somewhere that causes some form of restriction....The one in the BCS...... Don't F with that.
The restrictor pill in the clutch line..... Many people who go with an aftermarket clucth also get a stainless steel clutch line which has no restrictor pill.
Some of your info is misleading and incorrect, and potentially damaging. AFAIK, there are no clutchlines, either stock, or aftermarket, containing internal restrictor orifices. On the Evos, the hydraulic fluid restrictor orifice is located in the clutch slave cylinder.
BCS is the acronym for boost control solenoid. There is no restrictor pill in the BCS. Maybe you were just being a tad obscure.
Old Nov 30, 2007 | 08:03 PM
  #32
xxNosTankxx's Avatar
Had the right idea but just a little off, Thanks Sparky =)
Old Nov 30, 2007 | 08:27 PM
  #33
sparky's Avatar
Yeah, you had the right idea.
I just happened to recall the clutch fluid restrictor pill being in a port in the slave cylinder body. Eventhough, I didn't do the SS clutchline install myself, I was watching.
The factory boost-vacuum lines contain two strategically located restrictor pills( 2 separate locations).
EDIT: Incidentally, the factory boost controls, managed by the ECU through the BCS and the restrictor pills is a neat system. There are tuners on this forum such as "Razorlab" and others, who have modified and improved upon the system, achieving rock solid boost control at higher boost levels and great spoolup as well. If I was smart enough to understand how the factory system works, then I'd get rid of my MBC
Old Dec 1, 2007 | 01:53 PM
  #34
barneyb's Avatar
On my DSM the restrictor pill was in the boost solenoid itself. Anyway, the reason for the pill was that no two cars off of the assembly line would produce the exact same boost due to differences in parts and engines. So, in final checkout the correct pill was inserted to trim the boost to the amount desired by the factory. I suspect the same is true for the Evo.
XSivPSI
Dec 17, 2015 07:08 PM
ekinshuya
Feb 5, 2015 09:26 AM
teampruven
Evo X How Tos / Installations
Jul 29, 2014 02:02 PM
evohmoob
Sep 21, 2013 06:58 PM
Grey Razor
Mar 21, 2011 10:55 AM
