Boost restrictor pill location
Old Feb 3, 2015 | 09:37 PM
ekinshuya's Avatar
based on the above pix, anyone know FOR SURE if on the circle labeled 1 that there is a boost restrictor pill inside the tube like 1 inch from the openning? That side is connected to the stock boost solenoid and i pinched the ball size hard piece like 1 inch inside that openning.
#2= on the red circle 2 where there is that clamp that hold the other restrictor pill.....mine doesnt have that clamp where i circled. Does that mean its missing the restrictor pill there? i cant take it apart or reach enough to pinch and feel it cuz it require alot of removing. Anyone know for sure?
thanks first since u guys are great help
Old Feb 3, 2015 | 10:19 PM
Ryuartz's Avatar
I am 100% sure there is boost pill inside the circle 1. I removed mine once before and car didn't boost above the 10 psi.
Old Feb 3, 2015 | 10:48 PM
ekinshuya's Avatar
how about #2? would no clamp there indicate there being NO pill?
Old Feb 4, 2015 | 07:13 AM
llDemonll's Avatar
just feel around, you'll notice it
smarter thing would be to just replace the vacuum lines with new ones so you're sure there's no pill in there
Old Feb 4, 2015 | 07:37 AM
Ryuartz's Avatar
+1. There should be another pill inside the circle 2. I believe different size of pill.
Old Feb 4, 2015 | 11:50 AM
ekinshuya's Avatar
kk ill try get it replace. is it easy to do?
Old Feb 4, 2015 | 12:34 PM
llDemonll's Avatar
...it's literally 3 pieces of vacuum line. Take one off, measure it, cut new one the length, put it back on. repeat twice more
Old Feb 4, 2015 | 03:13 PM
Jush's Avatar
You wouldn't need the clamp. The pill is IN THERE and to remove it you'd need to absolutly destroy the pipe. Give it a squeeze (mine was in the very center).
Old Feb 5, 2015 | 09:26 AM
ekinshuya's Avatar
uea i figured i didnt need the clamp but in the reference pix i saw that they said a clamp is there to hold it in place....so i thought that since i didnt have one there it might not have the pill.... i still uavent checked it yet. its hard to reach
Crimson316
Jun 19, 2015 02:49 PM
bwanner
Aug 31, 2012 05:38 PM
mfp5011
11
Jun 17, 2010 11:55 AM
Kica
Jan 19, 2009 11:21 PM
