High oil pressure
Old Nov 28, 2007 | 08:16 AM
tony_b's Avatar
High oil pressure
At start up, my 100psi autometer gauge is pegged. When it warms up, drops down to about 25psi. Cruising under 3k, around 35-40 psi. Anything above 3500 rpms, it sits at 100psi and at WOT, pegged again.
I use Mobil 1 10W30 on a stock internal ed EvoIX.
Is this normal? I thought it should be roughly 80-100psi? Mine seems to be at 100psi most of the time and would go much higher at WOT.
thanks!
Old Nov 28, 2007 | 10:26 AM
dancarroll0283's Avatar
I have the Defi guages, and my oil pressue at start is about 80 psi, at idle is around 20-25 psi and wide open i've seen it hit over 100psi.... I've not had any problems at all with my car..... I hope this helps
Old Dec 3, 2007 | 10:39 AM
shadow1's Avatar
I have Stri gauges. My oil pressure (measured at the oil filter housing) is over 100 psi on cold startup. At freeway cruising speeds, my oil pressure is around 80. At fully warmed up idle, pressure drops to 14 psi.
LSs1Power
Apr 29, 2017 01:08 AM
onefast2gdsm
Dec 30, 2016 09:17 AM
Ude Lose
Sep 14, 2016 05:52 AM
sobo
Oct 11, 2010 11:06 AM
kaonashi
18
Jan 20, 2008 02:05 PM
