problem when flooring the gas pedal.
Old Nov 28, 2007 | 10:21 PM
hang187's Avatar
well i dont know what it is, but once in awhile when im cruising about 60 mph and then floor it my rpm would stay stuck at about 4k. it seems like its trying to jump higher but cant so i just let off the gas. any ideas? i got new transfer case, act clutch, and nkg iridium IX. i also had that problem before the new TC and spark plugs were in.
Old Nov 29, 2007 | 05:20 AM
MitsuJDM's Avatar
Does the car studder? This was a symptom of my po300, but it was happening to my at much lower speeds.
Old Nov 29, 2007 | 08:11 AM
dancarroll0283's Avatar
Are you running stock boost levels?
Old Nov 29, 2007 | 08:13 AM
Cause the car may be over boosting..... What gear are you in also?
Old Nov 29, 2007 | 08:58 AM
CrackerJackToy's Avatar
What boost do you get when hitting it?
Old Nov 29, 2007 | 05:07 PM
hang187's Avatar
will seem like it happens when i downshift into 4th and floor it. yes it does studder a bit. and my speed doesn't pick up any more. only once in awhile, most of the time its fine. if it continues i'll just take it to dealer and see what they say about it.
smoothevo
Mar 22, 2025 01:46 PM
kadir07
Feb 3, 2012 02:26 PM
stitch_sack
May 23, 2009 06:23 AM
W_evo8
Apr 8, 2009 07:11 PM
diddyX
Feb 4, 2009 03:15 PM
