Buschur mini radiator
Old May 15, 2008 | 03:38 PM
Boost3dxEvO's Avatar
Originally Posted by vwjeff
+1. Anyone tried it yet???
What fan do we use Chad, I have the slim fan from Buschur Turbo Kit.
If your car is a 100 percent daily.. I would recommend the CBRD . I'm about to order one.. have heard nothing but great things.. if you already have a slimline fan its 450+shipping (: .. the buschur one from your turbo kit would be perfect!
Old May 15, 2008 | 03:40 PM
sikrsix's Avatar
Originally Posted by weap0n
Correct me if i'm wrong but does dave's DD Evo an RS (meaning no A/C). Further too, it might not effect the temps but he only runs c16 race fuel.
Food for thought.
I have an RS, with A/C and a koyo running a turbotrix manifold and an sc61 turbo
(60 A/R). Fits, but barely. (Would've picked up a CBRD radiator if it came out a month earlier. lol) I live in Maine and was told not to get a mini radiator by David Buschur himself for my DD.
Old May 15, 2008 | 06:20 PM
vwjeff's Avatar
There are no mounting tabs for the fan brackets... have you seen the CBRD unit. I aint using those plastic push pins and putting through the radiator.
OH Trent where are you buddy... jeffy needs some custom fab done
**EDIT**
Very nice peice! just no where to mount the brackets
https://www.evolutionm.net/forums/sh...=CBRD+Radiator
Old May 15, 2008 | 08:23 PM
CBRD's Avatar
im fixing that for you guys, basically on dave's request.
cb
Old May 15, 2008 | 11:56 PM
David Buschur's Avatar
I have had no problems overheating, no a/c on my car. Al has run his on the street, no problems, so has Matt in N. Carolina. All of us have no A/C. Personally it makes no sense to run the small radiator if you have a car with a/c.
The CBRD is a full size radiator, bolts right in (other than fan brackets) and weighs as little as the small radiator when not filled with water.
Old May 16, 2008 | 07:20 AM
vwjeff's Avatar
cb
Thanks Chad! for the time being Trent is gonna tig me something up. I wanna be able to use my fan and brackets that came with my BR kit
Old May 16, 2008 | 07:24 AM
Bonestock!'s Avatar
cb
Thats good news since the plastic pins turned me right off.
Old May 16, 2008 | 07:40 AM
SloRice's Avatar
cb
sweet!
I'm sure I'll be contacting you about one of these.
Old May 16, 2008 | 08:26 AM
vwjeff's Avatar
Originally Posted by SloRice
sweet!
copy cat
Old May 16, 2008 | 08:37 AM
AWD Motorsports's Avatar
Originally Posted by duracell55
Warning - I correct myself I have a BR HTA 35r and the Koyo radiator does not fit you have to use the factory or a mini (not recomended for DD I'm told)
found out yesterday the hard way from what I see I guess only a 16g or a 20g will fit since the Koyo is like double the width, anyone correct me if Im wrong
I have put the BR 35r tubular mani on with a koyo full size and it fit fine.. neverthless i was running the BR mini radiator kit on my street car for several months and it never got hot unless i stepped on it mid day 90 degrees and went thru the gears on 30-40psi..
