works throttle body shaft seals
Old Dec 3, 2007 | 05:08 PM
evo150's Avatar
i am about to install the works throttle body shaft seals and in the instructions they say to use a seal insertion tool. i dont mind having to buy one for a proper installation. can anyone tell me the exact size i need to buy, or a specific tool for the job? or should i just buy the machevo seals because they dont require "special tools"?
Old Dec 3, 2007 | 05:17 PM
CrackerJackToy's Avatar
Its all the same installing them. You use c-clip pliers if I remember the instructions right.
Old Dec 3, 2007 | 05:49 PM
evo150's Avatar
i have the c-clip pliers. the seal insertion tool is for pressing the new shaft seal in place. unless i can use something else.
Old Dec 3, 2007 | 05:56 PM
FullOutPwr's Avatar
Do yourself a favor and stick with the Works aperture seals... Cant go wrong with any part they sell.
Old Dec 3, 2007 | 06:10 PM
Yeah I went with the WORKS... great product & no leaks.
Old Dec 3, 2007 | 06:46 PM
evo150's Avatar
no question that the works seals are great. just trying to figure out what you guys are using to "press" the seal in place.
Old Dec 3, 2007 | 07:30 PM
Aby@MIL.SPEC's Avatar
i dont know if a store-available tool exist.
i made mine on a lathe, basically imagine a big drift / punch & make the guide part the same diameter as the throttle shaft & ~1.5" long to be your guide & the part that pushes on the seal, make that ~+ 0.500 larger than the diameter of the seal....this will only push the seal flush with the body..
i made the pushing part a "step" & it sticks out about +0.030, which is the ~.010 smaller than the od of the seal, then i have the large section (+0.500 larger odthan the seal) to hit against the tb housing to know when the seal is sent home.
hopefully this helps out abit.
Old Dec 3, 2007 | 07:41 PM
dubbleugly01's Avatar
I've never checked the throttle body shaft for leaks, but is this a big deal? I mean a little leakage around the shaft isn't going to affect a/f's that much. Are you guys being **** (I mean that in a nice way!) or should I be a lil less carefree about it?
Old Dec 3, 2007 | 08:19 PM
FullOutPwr's Avatar
These will let quite a bit leak under boost... Just from these leaking, I cant hold 15 psi under a boost leak test for more than a second. Put that in terms under boost and load, it might cause for a slower car. No boost leak should be left un-fixed.
Old Dec 4, 2007 | 09:00 AM
mplspilot's Avatar
The insertion tool is called "A Right Size Socket", which you should have a bunch in your garage. Use a small amount of lube on the seal, put it in, put the socket on it and use a small hammer to get'er in.
And throttle shaft seals are prone to start leaking at some point on evos, and WORKS product is the best. I have those in too.
Old Dec 7, 2007 | 06:26 PM
evo150's Avatar
ended up using your method and it worked out perfect
Old Dec 7, 2007 | 11:02 PM
mplspilot's Avatar
Glad to help!
Old Dec 11, 2007 | 11:13 AM
LayinLo's Avatar
evo150, what size socket did you end up using?
Old Dec 11, 2007 | 11:20 AM
LayinLo's Avatar
OK, found this:
https://www.evolutionm.net/forums/sh...d.php?t=220264
Old Dec 14, 2007 | 09:05 AM
evo150's Avatar
not to sure what size socket i used. i started off with a socket just slightly bigger than the new seal. after i got it tapped in level with the t/b opening i used a socket the exact same size as the seal to finish tapping it into place
snowborder714
For Sale - Miscellaneous Automotive
May 6, 2017 06:22 AM
3gevoclipse
Jul 31, 2016 10:18 AM
roni4g63
Jan 31, 2016 04:23 PM
Brsox10288
11
Sep 26, 2014 08:09 AM
idriveanevo
Apr 22, 2007 08:40 PM
