gt35 on stock block?
Old Dec 4, 2007 | 07:31 PM
EVOLV3D's Avatar
ok i want to put a gt35r on my evo without building the motor how much can the motor hold, and what can i put out on pump gas(maybe alky) safely?
Old Dec 4, 2007 | 07:38 PM
vwjeff's Avatar
See my signature
dubbleugly01's Avatar
why did you pick the 35R for stock motor and pump gas (and maybe alky) ? What are your supporting mods?
Old Dec 4, 2007 | 08:10 PM
Evoluvin's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=310751 need i say more??? and he has 50K on the ODO
Old Dec 4, 2007 | 10:29 PM
big block ix's Avatar
if you are positive about using Meth i say go for it! if you only plan on using pump gas you will be hatin life with the lag... i had a 35r on my old IX and the lag was terrible, the big pay off of 375WHP+ is kind of lack luster with the lack of torque at all Rpm ranges on pump
Old Dec 5, 2007 | 04:55 AM
you yourself questioned whether that was reliable and a smart decision If you plan on running mainly pump gas on the street with stock block, the 35R imo is not a good turbo choice. If all you want is a peak number, fine, but if you want decent driveability, and it is a DD, there are better/smaller turbo choices out there. I like area under the curve more than a peak number. Just my two cents.
Old Dec 5, 2007 | 06:23 AM
EVOLV3D's Avatar
well what would you guys suggest i use i want to run around 450whp
Old Dec 5, 2007 | 06:36 AM
deadbeatrec's Avatar
3076r-3037s with meth.
Old Dec 5, 2007 | 06:38 AM
MRadjahoe's Avatar
SEE my signature dude. and I didnt even hit 30psi!
Old Dec 5, 2007 | 07:35 AM
jmartinez1170's Avatar
I say get any turbo kit that you would like useing the 35R or 30R . Injectors 880cc, and a dyno tune for 93oct.
Supporting mods
catback
ic with uicp and bov
and a clutch non ACT lol.
head studs a must.
and if you want but not really needed some cams.
With that you should see anywhere from 350-540 depending on turbo, fuel and psi
Old Dec 5, 2007 | 07:49 AM
precisi0n's Avatar
73,000 on the clock, 525hp with 35r. If you want good power and dont want to worry about reliability of the motor, go with the FPGreen, 272's, ported intake/exhaust, and a good tune.
Old Dec 5, 2007 | 02:37 PM
ETS Michael's Avatar
My EVO made 599whp at 30psi on our 35R kit on stock internals with only ARP head studs and rod bolts inside the motor. We had another customer make 669whp with the same kit and some nitrous on the stock internals. The EVO 4g63 is very stout and will take a lot with a knock free tune, but running them this hard elminates most of the room for error. If you were to have an erroneous knock episode at that power level you're far better with ugpraded rods/pistons that will take a little bit more abuse, but a massive detonation session is likely going to pop the motor either way. Upgraded internals offer a little more wiggle room but don't make the motor bullet proof. Hope that helps! If you have other questions that I could answer just let me know
Tom
Old Dec 5, 2007 | 02:44 PM
20Grockit's Avatar
im gonna go with a 30r
Old Dec 5, 2007 | 08:12 PM
EVOLV3D's Avatar
so what can i run awhp wise and quarter mile times with a evo green, gt30r and gt35r all on pump gas and meth?
Old Dec 5, 2007 | 09:24 PM
precisi0n's Avatar
all three turbos have gone 10's
