quick turbo/boost question
Old Dec 6, 2007 | 10:21 AM
shanezt's Avatar
hello, i have an 05 evo. i have been fighting a boost problem for some time. my car will not hold boost. i did the boost leak test to 25psi, held fine. at this point i have unplugged the w/g actuator and wired the wastegate shut! i get a spike to 20psi then it drops al the way down to 5psi above 6k rpm. now if i keep it at part throttle it will hold boost alot better, but as soon as i hit WOT it drops fast.
the car has cams, dv, intake, exhaust, new plugs, apex neo, header, 680cc inj,
i logged a 3rd gear pull and front 02 showed .95 volts timing stayed good also.
the car is new to me and a wild thought is that maybe it has a stroker motor and is just overspinning the turbo. not likely but i think it is either that or a junk turbo.
any help would be nice, thanks
Old Dec 6, 2007 | 10:25 AM
kaonashi's Avatar
that sounds very odd
Old Dec 6, 2007 | 10:52 AM
spdracerut's Avatar
Really odd... I can only guess that it's the DV. Try putting back on a stock valve and see what happens.
Old Dec 6, 2007 | 11:14 AM
shanezt's Avatar
sorry forgot to add that the dv is a forge and i have adjusted it every way i can. i dont have the old one.
Old Dec 6, 2007 | 11:27 AM
mplspilot's Avatar
So what's the boost control method on this car?
Old Dec 6, 2007 | 11:37 AM
shanezt's Avatar
wastegate wired shut
Old Dec 6, 2007 | 12:32 PM
grillpt's Avatar
Could be the WG actuator. My actuator went bad and I couldn't boost right, not even when the WG lines were off. My car would spool to 15lbs and then drop like a rock. Those days sucked...
Old Dec 6, 2007 | 12:43 PM
spdracerut's Avatar
He already eliminated the possibility of it being the WG actuator because he removed it and wired the wastegate shut; which is why I'm guessing the DV. Maybe someone around you has one that you can borrow?
Old Dec 6, 2007 | 12:46 PM
Jeff_Jeske's Avatar
If you artificially create boost at the turbo and it holds 25psi then the DV and such should be good to go. The problem then points to the source of the boost... the turbo... Check to see if the exhaust manifold to turbo bolts are tight and the gasket is solid. You may even want to spin the turbo by hand to see if it freely spins.
Old Dec 6, 2007 | 03:47 PM
20Grockit's Avatar
sounds like a faulty dv to me. it doesnt sound like an exhaust leak
Old Dec 6, 2007 | 05:42 PM
shanezt's Avatar
thanks for the input, i will block off the dv next.
Old Dec 6, 2007 | 08:37 PM
Jeff_Jeske's Avatar
Put the stock one back on to see if it holds. I wouldn't block the forge off as bad things might happen.
Old Dec 6, 2007 | 08:39 PM
06rs_power's Avatar
sounds like the dv to me
Old Dec 6, 2007 | 08:44 PM
turboracer's Avatar
Pull the intake hose of the turbo and grab the bolt that is in the center of the hole in the front of the turbo. Try to move the bolt in and out of the hole. You should have almost no movement. If it moves in and out then you need to look at your turbo. Bad thrust bearing can cause the compressor to machine itself down to almost nothing and produce the symptom you describe. Ask me how I know about this one
Old Dec 7, 2007 | 05:50 PM
20Grockit's Avatar
yes thats true i didnt even think about it til mentioned but my friend has a 240 with a s13 swap and that happened to his turbo
BlackSE
Apr 20, 2011 09:28 AM
Taimur
Jun 19, 2010 02:51 PM
cpunlamd
22
Jun 15, 2010 07:05 PM
kapolani
33
Apr 8, 2008 03:01 PM
Andrew LB
Apr 25, 2006 06:25 PM
