Throttle mayhem...
Old Dec 9, 2007 | 04:54 PM
barneyb's Avatar
On my dsm, I pulled the throttle body, removed any parts I thought wouldn't like solvent and dunked it in carburetor cleaner. The result was a lot of black stuff being removed - especially when I blew out the vacuum ports.
Old Dec 10, 2007 | 02:41 AM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
I will try and adjust my throttle screw to 1200 then reduce it with the software and see what that gives me...If it doesent sort out the problem i will take off the throttlebody and give it a good clean with carb cleaner and inspect for obvious problems...
Thanks for all your input guys...
Old Dec 10, 2007 | 03:48 AM
dxbevo9's Avatar
i had the same ZzZz noise...however i dont recall my pedal was any stiffer...
also...i believe the HKS FPR is whats causing this...we both hae the same FPR...
Old Dec 10, 2007 | 07:10 AM
dxbtune's Avatar
^ true maybe the sound and stiffness arent related... coincidently the sound occurs during the opening of the throttle and could be when the fpr does its thing...
Mellon Racing
209
Jun 18, 2011 08:10 AM
dxbtune
Oct 19, 2009 11:30 AM
dxbtune
11
Oct 18, 2009 04:32 PM
dxbtune
15
Aug 28, 2008 01:48 AM
dxbtune
28
Mar 27, 2008 08:27 AM
