evo green spool
Old Dec 19, 2007 | 09:10 PM
  #106
cfdfireman1's Avatar
Pretty wild that the green will make 20 psi with the waste gate wide open.
Old Dec 20, 2007 | 06:12 AM
  #107
FastAzzEvo's Avatar
No doubt, when I saw it I couldn't believe I was getting that much boost....
Whats funny, is I ran down "SLOWLY" a modified A4 on the highway..
Old Dec 20, 2007 | 06:51 AM
  #108
I should be getting my green in about 3 weeks. What size injectors are you using with yours?
Old Dec 20, 2007 | 06:55 AM
  #109
TeStUdO's Avatar
He's using 780's
Old Dec 20, 2007 | 06:58 AM
  #110
sillyrpm's Avatar
good luck with it....can it be on the tune too..?
  #111
TeStUdO's Avatar
He figured out the problem.....thanks for actually reading the thread.
Old Dec 20, 2007 | 07:36 AM
  #112
FastAzzEvo's Avatar
yeah pte 780's...
Old Dec 20, 2007 | 09:32 AM
  #113
mplspilot's Avatar
noobz.
Old Dec 21, 2007 | 02:06 PM
  #114
FastAzzEvo's Avatar
well got the new housing today. , but its a single flapper with two holes in the housing.. They look significantly smaller so I'm worried about flow...
Anyone know if I will notice any difference between the two?
I'll post pics of the new housing in a few.
Old Dec 21, 2007 | 03:05 PM
  #115
Erik@MIL.SPEC's Avatar
The single flapper is an evolution of the dual, so it should be as good as if not better. I have read somewhere that they're basically the same performance-wise.
Old Dec 21, 2007 | 04:23 PM
  #116
Aby@MIL.SPEC's Avatar
if you were targeting a boost level of 5 psi, i would want the twin flapper housing, but since 99.9% of evo owners are targeting a boost level >20 psi, the amount of flow out either of the 2 turbine housing should be fine.
Old Dec 21, 2007 | 04:50 PM
  #117
gtpumps's Avatar
They did say I had the 10.5 housing, at least that was on the receipt, it is not stamped on the hotside......
Yes it is "105" means 10.5 cm2
Old Dec 21, 2007 | 05:30 PM
  #118
FastAzzEvo's Avatar
yeah that was like so 1 week ago. thanks though.
Old Dec 21, 2007 | 08:19 PM
  #119
sparky's Avatar
You'll be fine with the single flapper! This is the better housing anyway. I don't kow how you ended up with the dual flapper on your Green in the first place.
Old Dec 21, 2007 | 08:51 PM
  #120
redlaybal's Avatar
i got green and i dont see that problem at all. Hope things work out
