Which Internals!!!!
Old Dec 9, 2007 | 11:14 AM
dxbevo9's Avatar
thanks ifat=rted2...what pistons do you recommend?
Old Dec 9, 2007 | 11:27 AM
Paul Nelson's Avatar
Ive been running the Arias pistons. Ive heard good about JE,wiseco also
Old Dec 9, 2007 | 11:42 AM
Ted B's Avatar
Originally Posted by evodan2004
how good are Venolia and Oliver pistons and rods?????
Let's just say that if one experiences failure of a part from either of these producers, it's rarely the fault of the part.
Old Dec 9, 2007 | 07:57 PM
dxbevo9's Avatar
very well put together statement...
i think i am settling with the JE pistons and Crower rods
Old Dec 9, 2007 | 08:17 PM
ExViTermini's Avatar
Crower/Wiseco combo here. They've been proven to hold up in many high HP cars as well as daily drivers.
Old Dec 9, 2007 | 08:20 PM
scorke's Avatar
Was Eagle/Wiseco now Crower/Wiseco with an Eagle crank.
I am swapping out Clevite bearings for Calico Coated ones.
Bearings and Crank should be addressed too, maybe rod bolts See what goes and what doesnt?
Scorke
Old Dec 9, 2007 | 08:28 PM
TTP Engineering's Avatar
Hey guys,
I am looking for the best combo of forged internals for my 2.0L Build.
Please do not consider money in your suggestion. Maximum reliability is my primary concern.
My options for pistons are:
-JE
-CP
My options for the rods are:
-Manley I-beam turbo tuff
-Crower Rods
-Carrillo H-beam
Do not feel limited to my options, please feel free to suggest something else if need be
Thanks in advance
Respect
Moose
Check out our custom pistons here: Best available...
https://www.evolutionm.net/forums/sh...hlight=pistons
Conbined with Manley Ibeam Turbo Tuff rods and you have a 1200hp capable setup.
Old Dec 9, 2007 | 08:32 PM
EVO8emUp's Avatar
If you're going to be pretty much replacing the entire rotating assy. Do a 2.3L. I promise you will thank me later.
Old Dec 9, 2007 | 08:33 PM
kouzman's Avatar
I would buy a set for Cosworth pistons/rings/rods... of course they are like 2500 dollars so most of them wouldn't do it...
If i wanted to stay on a "normal" price range i would either do a numerous times proven set from either Buschur or AMS (oliver rods...)
Old Dec 9, 2007 | 08:52 PM
scorke's Avatar
Buschur doesn't use oliver rods.
AMS reccomends Oliver Rods and Ross pistons in everything but a budget build(eagles) or an all out drag car which they reccomend the Groden's.
Scorke
Old Dec 9, 2007 | 08:58 PM
RedLanEVO's Avatar
i am going to run wiseco/eagle so i will let you know how it goes
Old Dec 9, 2007 | 09:08 PM
scorke's Avatar
It will be fine, i ran them with no issues till i ran low on oil
Good for 500 whp no problems.
Scorke
Old Dec 9, 2007 | 09:09 PM
dxbevo9's Avatar
what rev limit can those approximately handle...?? i know this also depends on other factors as well...but just an approximate figure
Old Dec 9, 2007 | 09:11 PM
scorke's Avatar
Rod's are not held to rev limits, valve springs are/ rotating assemblies are.
Scorke
Old Dec 9, 2007 | 09:16 PM
dxbevo9's Avatar
Scorke
i thought pistons and rod BOLTS were? no?
i already have valve springs and retainers procured.
