Compressor leak test... help...
Old Dec 14, 2007 | 06:20 AM
ItalianEvo's Avatar
Hello,
i closed the inlet and the outlet of my GT3071 compressor side.
Then i continuously fed it with 2 bar of compressed air, but i read a maximum of 0.5 bar in the turbo's compressor side.
I hear that the air is escaping through the turbo oil outlet...
Is it normal for you?
TIA.
Old Jan 29, 2008 | 09:21 AM
ItalianEvo's Avatar
Please help me... tia...
Old Jan 29, 2008 | 09:59 AM
KevinD's Avatar
when doing boost leak tests, when i have the compressor in the system air does not leak past the seals on the compressor.
obviously if the seals were bad, then air would slip past them.
i've also heard that you need oil pressure for air to not slip past the seals, but boost leak tests are always done with the car off, and the crank case never gets pressurized.. therefor oil pressure shouldn't make a difference.
Old Jan 30, 2008 | 08:01 AM
ItalianEvo's Avatar
Ah... ok...
so something is wrong inside...
Thanks
Old Jan 30, 2008 | 08:07 AM
TiALSport's Avatar
turbos do not have 'seals' they have a step in the shaft which acts as a seal
the turbo is fine, i would assume the car wasn't running when you did the test?
Old Jan 30, 2008 | 08:53 AM
AlwaysinBoost's Avatar
Originally Posted by ItalianEvo
Hello,
TIA.
I think you're doing it wrong. All you need to do is pull your intake off from the compressor inlet and put the tester on that. you shouldn't disconnect or close off anything else (except if you have an MBC you will need to tighten it so it doesn't bleed off). Pressurize the system and listen for leaks.
Old Feb 3, 2008 | 01:19 AM
ItalianEvo's Avatar
No, the turbo was off the engine...
So you think I had a good test ??
How do you make your tests ?
Thanks...
Old Feb 3, 2008 | 01:21 AM
ItalianEvo's Avatar
I already made this test... and it helped me to find a pop off flange leak...
But this I made is strictly a compressor leak test, not an intake sytem test, because I have to find why my sump is getting pressurized... and I think the problem should be here...
Bye.
