MAF Implosion!!!
Old Dec 14, 2007 | 05:02 PM
  #31
hawaiian_evo's Avatar
Originally Posted by EvoJoeIX
time to start running speed density
I would love to go aem or maft pro but ams aint planning to come back to the big Isle for another year or so.
so im probly going to buy another stock maf then save up for a aem and when chris comes back woot woot.
Then again i heard aem dravability kinda suck( I need to do more research on this )
  #32
MalibuJack's Avatar
A bit of epoxy around the perimeter will keep it intact... If the screen is in pristine condition, it won't happen, but as soon as the honecomb gets distorted, either from debris or handling and/or very high airflow, then of course, it will start generating a bit of lift here and there, eventually it'll collapse in on itself.
The safest solution is to be proactive by gluing it. I use a blowthrough setup, I just can't really recommend speed density, it works, but has quirks... given enough time it can be set up to work well though. There aren't many options, you have the stock MAF, an alternative MAF and translator device, and speed density. the least work is going to be keeping the stock MAF.
The biggest problem is some options (a standalone running speed density) has legality issues, that is not many states/towns/etc have safety only inspections where you can get away with it without a hookup.
Old Dec 14, 2007 | 05:06 PM
  #33
hawaii safety inspection only checks lights, exhaust, tint, and blinkers so emmision isnt a issue.
I was looking into a blow through system but like malibu jack says its hard to fine tune and it takes time. Im not the smartest guy so i dont want to get myself into something like that. I wouldnt mine learning though
Old Dec 15, 2007 | 05:49 AM
  #34
Ted B's Avatar
Suction did not cause this. It was only an aggravating factor after the fact.
What caused this was a blast of air, coming through in the opposite direction. When this happens, the best explanation is that a burst of air from the BOV is the most likely culprit.
A BOV that vents into a 'T' just behind the MAF sensor is a prime candidate for this sort of thing. The best way to engineer a BOV vent is to place it at a shallow angle, just in front of the turbo, aimed right into the compressor. This prevents any BOV blasts from becoming a jet of air that blows backward through the MAF.
Old Dec 15, 2007 | 08:29 AM
  #35
scheides's Avatar
EvoM Moderator
+1, but also can be aggravated by vibration, i.e. doing a launch....a bad launch?
Do you have any pictures of how to properly expoxy it?
....HawiianEvo, consider yourself lucky. Often when this happens the car is under heavy load and traveling high speed, the car goes way lean and results in the pistons and rods making holes through the side of the block! I've seen it in person, it is not a nice thing!
Old Dec 15, 2007 | 08:46 AM
  #36
juice_evo_VII's Avatar
Dayuuum
Old Dec 15, 2007 | 12:32 PM
  #37
CrackerJackToy's Avatar
Your lucky it didnt go into the turbo, or even your engine for that matter.
Old Dec 15, 2007 | 12:49 PM
  #38
I have an 04 evo does anyone know if a 2005 evo 8 or evo 9 maf will work???
Old Dec 15, 2007 | 12:58 PM
  #39
Thegame's Avatar
yes
Old Dec 15, 2007 | 01:01 PM
  #40
thanks. And yes i guys I consider my self lucky
Old Dec 15, 2007 | 05:47 PM
  #41
C6C6CH3vo's Avatar
One crushed honeycomb section creates enough pressure to do that
Especially at high airflow
Old Dec 20, 2007 | 07:45 AM
  #42
well my honeycombs were in perfect condition
Old Dec 20, 2007 | 11:49 AM
  #43
Joshs EVO's Avatar
AHH that's why you needed my MAF. I hope you enjoy it and it works out for you.
Old Dec 20, 2007 | 12:48 PM
  #44
Mad_SB's Avatar
You could also do a blow through conversion, you need a maf translator, a 3" gm maf, and some intercooler pipe work.
hawaiian_evo
Sep 8, 2009 08:36 AM
hawaiian_evo
Aug 24, 2008 07:17 PM
BlackIX
Nov 13, 2007 08:18 AM
hawaiian_evo
Jun 22, 2007 10:17 AM
hawaiian_evo
May 1, 2007 05:59 PM
