Going BB worth extra 500$
So im basically left to my last choice's now ive narrowed it down to the turbo I want, and its going to be:
A. Garrett T3/T40E 57trim 4bolt T31 575$ or 1010$ Ball bearing upgrade.
53LBs/MIN
B. Precision SC3431E 57trim 4bolt T31 800$ or 1080$ for Ball bearing SC3432RE
54LBs/MIN
Man choices is the extra 500$ worth the ball bearing upgrade? i know it spool's faster but I have heard ball bearing turbo's are more reliable with higher boost level's and is a big factor here.
53LBs/MIN
54LBs/MIN
Well I look at it this way , the ball bearing centre section will take the shaft speeds and loads that kills bush/plate centre sections . Every time you really lean on a bush cartridge you risk the old style bearings failing and when they do the wheels hit the housings and damage those as well .
Just before the bush wackers rally in defence remember this . A Garrett GT25 BB centre section is compact and light and losely based dimensionally on the GT25 bush centre section . It is difficult to compare them to a mechanically larger T3/small shaft T4 or a GT bush bearing centre section . The GT25BB CS offers better shaft support against radial and end thrust loads but really is a smallish CS . The larger GT BB CS is based around the GT bush Cs and they are a pretty robust bit of gear .
Out of curiosity what sort of power claims do they have for the 57 vs the 50 trim ?
I'm not 100% sure but I think the 50T is a slightly different (later) version of the 76mm T04E compressor family . The only 50T T04E compressor map I've seen looks pretty good and if your driving it with a 76T TB31 turbine I'd think the turbine/compressor match would have to be pretty good if its to have reasonable response and good transients . I've not used those BB TB31/T04E turbos but what I have heard is go the 50T - probably because T04E compressors were originally intended to be driven by larger 74mm T4 turbines .
Thoughts ?
Thoughts ?
Thoughts ?
Thoughts ?
On precision websites the 57trim is rated 95 more HP over the 50trim. they are almost identical i believe except the actually turbines used
If you have ever seen how long a ball bearing turbo will spin when you shut the motor off, the choice is easy. The difference in spool really isn't that big, it is really how long the turbo stays spooled in between shifts.
When your bangin through the gears, the response is killer.
Extreme Tuners
Jul 19, 2012 09:59 AM
AutoMotoSports
Automotosports - Illinois
Sep 15, 2009 08:14 AM
Darius@AMS
Feb 9, 2009 09:06 AM
rt turbo
Apr 25, 2004 07:58 AM
