Those who have boost guages that read in "BAR"
Old Nov 25, 2003 | 04:33 PM
  #46
gunzo's Avatar
Originally posted by Sweft
If you're getting **** on the guy let me get **** on you.
Rounding off to 5 significant digits 1 bar is equal to 14.504 PSI. To 9 significant digits it's equal to 14.5037738.
Just heads up for guys comparing gauges to boost controller readings ..
1 is in BAR (boost controllers)
1 is in KPA (gauges)
KPA reads higher .. IE you'll see 1.3 bar on the boost controller and 1.4x100 KPa on the gauge ..
It's slightly off .. just go find the conversion website
Anyway .. I set both the boost controller and the gauge to read KPa and I still can't get them to sing the same song even though both are tapped from the same place
Old Nov 25, 2003 | 05:08 PM
  #47
MYEVOVIII's Avatar
Mine at idle with Blitz DTT is -700 something I think and after warms up around -500.I will try to look at it tomorow and check again. I am just going by memory
Old Nov 25, 2003 | 06:54 PM
  #48
Thoe99's Avatar
Ah, that explains everything! Mine reads in hkPa (blitz dtt 2). I just looked it up that 1 hkPa = 14.7psi. I've been under the assumption that that was bar (14.5psi for 1bar).
Old Jul 10, 2004 | 10:04 PM
  #49
revhappy's Avatar
Since 1 PSI = .145 kpa, shouldn't h (hecto) kpa be 100 X .145 = 14.5 PSI?
Old Jul 12, 2004 | 01:09 AM
  #50
GokuSSj4's Avatar
bar to PSI Conversions
0.1 bar = 1.4504 PSI
0.2 bar = 2.9008 PSI
0.3 bar = 4.3511 PSI
0.4 bar = 5.8015 PSI
0.5 bar = 7.2519 PSI
0.6 bar = 8.7023 PSI
0.7 bar = 10.1526 PSI
0.8 bar = 11.6030 PSI
0.9 bar = 13.0534 PSI
1.0 bar = 14.5038 PSI
1.1 bar = 15.9542 PSI
1.2 bar = 17.4045 PSI
1.3 bar = 18.8549 PSI
1.4 bar = 20.3053 PSI
1.5 bar = 21.7557 PSI
1.6 bar = 23.2060 PSI
1.7 bar = 24.6564 PSI
1.8 bar = 26.1068 PSI
1.9 bar = 27.5572 PSI
2.0 bar = 29.0075 PSI
2.1 bar = 30.4579 PSI
2.2 bar = 31.9083 PSI
2.3 bar = 33.3587 PSI
2.4 bar = 34.8091 PSI
2.5 bar = 36.2594 PSI
2.6 bar = 37.7098 PSI
2.7 bar = 39.1602 PSI
2.8 bar = 40.6106 PSI
2.9 bar = 42.0609 PSI
3.0 bar = 43.5113 PSI
spt
Jul 28, 2012 04:55 PM
Bimmubishi
11
Oct 13, 2008 08:03 AM
