knock? blown engine? plz help!!!
Old Dec 22, 2007 | 01:38 AM
pashasevo's Avatar
okay guys, I was driving my evo IX tonight an i was doing some 1st thru 4th gear pulls. Everything seemed fine as I went through 1st, 2nd, and 3rd. When I shifted into 4th gear the car made a very strange POP noise...to the point that it actually scared me. It was something that I have never heard before, almost like something hit the car, although it did seem to significantly lower the power of the engine an forced me to decelerate. Well to be sure of the problem, I tried the 1st-4th gear pull again and sure enough all went well an nothing happened. I went a third time to be sure the problem is resolved, when sure enough again the problem reappeared. The exact same POP noise, only as I accelerated in 4th gear. I have NO IDEA what it can be and I am very worried about my precious baby .....the car has 21k miles on it wiith no mods besides full turboback exhaust. Please let me know what this can be...any help is appreciated....thanks in advance.
~Pasha
Old Dec 22, 2007 | 01:50 AM
khara's Avatar
Definitely this is not knock. but it can be worse than knock.
21k miles on a stock turbo!
did the car had Nitrous abuse?
Just enjoy the car and start saving for your engine buildup!?
shiiit happens man
Old Dec 22, 2007 | 01:51 AM
subrwho's Avatar
Either your upper or lower intercooler pipe popped off. It happens all the time to people. Time for t-bolt clamps!
Old Dec 22, 2007 | 02:05 AM
sillyrpm's Avatar
yea..t bolts does the job...
Old Dec 22, 2007 | 02:11 AM
BBS's Avatar
BBS
If any of his ic pipes popped off, then the car would stall and wouldn't run at all. Sounce like you overboosted and hit fuel cut. Get your car tuned and find a decent boost management solution and problem solved.
Old Dec 22, 2007 | 02:39 AM
pashasevo's Avatar
thanks for the replies so far guys....and NO the car did not have ANY nitrous abuse of any sort.... I am just very confused as what it could be, because although it sounds like the IC pipe being popped off, that couldn't be it since the car runs fine with the exception of that 4th gear issue. Please keep em coming, any info is helpful....thanks guys
Old Dec 22, 2007 | 02:42 AM
subrwho's Avatar
when it *pops* how much are you boosting when this happens?
Old Dec 22, 2007 | 02:45 AM
subrwho's Avatar
Also, is it a single pop or multiple pops? What was the weather like?
Old Dec 22, 2007 | 02:52 AM
krazirob's Avatar
yeah monitor the gauges and see what happens before during and after if you can. Could just be hitting a fuel cut, the ecu will pull timing if you start to knock and the car will sputter a bit but no POP............you running a MBC??? aftermarket BOV......????
pashasevo's Avatar
its a single pop, the weather was pretty cold probably under 60 degrees......thanks again
Old Dec 22, 2007 | 02:53 AM
pashasevo's Avatar
also....i have NO mods besides full turboback exhaust....the boost/tune has never been adjusted.....
Old Dec 22, 2007 | 02:54 AM
subrwho's Avatar
Backfire maybe? Mine does it once in awhile because I have a test pipe
Old Dec 22, 2007 | 02:56 AM
krazirob's Avatar
also what RPM was you at??????
Old Dec 22, 2007 | 02:58 AM
pashasevo's Avatar
I was thinkin about backfire as well, however the engine seemed to die which would mean it had to be something else, also I was mid rpm range, id say around 5-6k
Old Dec 22, 2007 | 03:02 AM
subrwho's Avatar
Die? Did you comletly let off when it popped? Was it like the car completly lost power when it popped? (Sorry for playing 21 questions, but I wanna help you figure it out lol)
