Perrin FMIC users please help!!!
Old Dec 25, 2007 | 03:43 PM
Inprogress's Avatar
Update: It seems I'm missing some spacers for the drivers side bracket. I am now running into a different problem, even after using a wack-*** spacer that I had laying around the house, the core still doesn't line up. The driver side bracket with spacer make the passenger side bracket stick out making it look like the passenger side needs a spacer too, but from some install pic's it seems the passenger side doesn't have a spacer. Nothing seems to line up.
Am I doing something incorrectly?
Please, any help would be greatly appreciated!
I am in the process of installing my Perrin FMIC and can't seem to get it to fit. There are hard lines right below it that are hitting the back of the FMIC and not letting it fit/line up properly.
Even when I make it connect with the one side, the fmic looks lobsided and hits these two hard lines (if you stare at the bumper then the left end tank).
Here's a pic of the line it hits at the bottom, its the one by the black hook
I bought the FMIC used and all I got were 2 couples plus the core, should there be more to help with the install? ANY HELP WOULD BE REALLY APPRECIATED!!!
Thanks
Old Dec 25, 2007 | 03:47 PM
moreryce's Avatar
r u talking about the intercooler not looking even on both sides? dont you know that even the stock one doesnt line up in the center of the bumper..?
heres a pic of the stock one..
Old Dec 25, 2007 | 03:51 PM
Inprogress's Avatar
No, it's not about it looking straight or even, it's about it hitting the hard lines and not allowing the FMIC to even go on
Old Dec 25, 2007 | 03:57 PM
moreryce's Avatar
o i c.. hrm.. i have the buschur full race FMIC and it hits them but it still fits.. i would just suggest to bend them back a bit
Old Dec 25, 2007 | 03:59 PM
Inprogress's Avatar
I don't know if I want to be bending anything to be honest...I'm hoping some perrin user's may shed some light, I don't want to be hasty.
Old Dec 25, 2007 | 04:06 PM
Inprogress's Avatar
Looks like it does need spacers + longer bolts...
Here's a good install guide that may help others...
http://www.diynetwork.com/diy/ab_eng...213000,00.html
Any know if it needs anything else?
Old Dec 25, 2007 | 05:02 PM
jasnm21's Avatar
When I installed my perrin, I had to loosen all on the intercooler piping and get a longer coupler for the uicp just so it would "fit" correctly. I could only get the top mount to line up without any modification. Going Buschur next time.
Old Dec 25, 2007 | 05:46 PM
CBRD's Avatar
well, ill look tomorrow, sorry, the car that it was on, had a stripped bolt on the driver's side in the rad upright where the intercooler bolts too, so i probably threw the other bolt out..
i have some, they are standard thread pitch, and im sure i have some spacers too,
ill send them to you tomorrow priority mail!!
happy holidays
cb
Old Dec 25, 2007 | 06:45 PM
Inprogress's Avatar
Thanks a bunch Chad, hopefully this FMIC lines up correctly!
Old Dec 25, 2007 | 09:24 PM
Inprogress's Avatar
Any suggestions?
Old Dec 25, 2007 | 10:19 PM
555R's Avatar
cbrd is hooking you up man
mine went on too easy and fit perfect
the front end look mean since its all cooling fins now
Old Dec 26, 2007 | 06:16 AM
CBRD's Avatar
yeah, we never have fitment issues with the perrins core...
i forgot to send the bolts, since it was a used core, but that is my mistake, they are going out today overnight...
i always remove the licp or atleast move it FAR out of the way to get the core into place and bolted up... you may have to leave the top nut (on the stud from the center rad support) loose, and the two bolts before you fit the ic pipes.
cb
Old Dec 26, 2007 | 09:17 AM
EVIL_EV0's Avatar
Doesn't the perrin only have 2" inlet and outlets?
Old Dec 26, 2007 | 09:53 AM
555R's Avatar
Old Dec 26, 2007 | 10:14 AM
CBRD's Avatar
no
cb
