AMS 2.3L Stroker and Twin Scroll 35R with HTA Upgrade
Old Dec 29, 2007 | 12:25 PM
  #31
crcain's Avatar
Can't wait to see a dyno result with this Turbonetics 35R.
Lot's of hype... hope to see results soon.
Old Dec 29, 2007 | 12:28 PM
  #32
tseitz123's Avatar
Hi all! Thanks for the input. I'd be going to Sean Ivey or TurboTrix here in NJ for the tuning, I suppose. And to answer your question regarding the F1 turbo in the Full-Race kit... I will be opting for the Garrett 35R, not the F1. They have a twin-scroll version of it at Full-Race, so the HTA upgrade is def doable according to Jarrod at Buschur So yeah, 500whp+ is nice and I hope to post results when she's all done
Old Dec 29, 2007 | 12:29 PM
  #33
crcain's Avatar
So Full-Race has decided to not use the Turbonetics turbo they originally promoted in their 35R kit?
Old Dec 29, 2007 | 12:33 PM
  #34
tseitz123's Avatar
NO no no ! They Full-Race includes the Turbonetics F1, but I'm swapping that for the Garrett
Old Dec 29, 2007 | 12:56 PM
  #35
crcain's Avatar
No results yet for twin-scroll 35R!
Bring it on!
If it works I guess we'll see AMS and Buschur start making them?
Old Dec 29, 2007 | 01:12 PM
  #36
Erik@MIL.SPEC's Avatar
Turbonetics F1 TS 35 is a T4. The FP HTA converstion will only work with the T3 Garrett TS 35R.
Old Dec 31, 2007 | 12:20 AM
  #37
chuntington101's Avatar
Originally Posted by jmartinez1170
Ok becasue one car in UK hit 1000hp on a engine dyno doesnt mean anything unless its to the wheels. Its cool and all but who cares over here we have been there and done that almost 2 years ago.
In this case the guy wants to go with a 35R some people dont need 800whp on the street. 450-650 is just fine.
Look at it this way. Ive been in a 42R evo and i drove it for the day as soon as i hit 20psi i was already about to hit the car that was 25 cars infront of me and he was tuned for 40psi. Its pointless.
what was all that about??? sorry mate but did you read my post???
i said he should beable to make over 600bhp with a good tuner. that was the answer to the question not some UK/GT42/2.3/wheel power/ what ever bashing!
and you didn't even answer his question!
the only point i was making is its all down to the mapper! get that bit right and making power is easy.
Chris.
Old Dec 31, 2007 | 10:50 PM
  #38
Talonboost's Avatar
The HTA is no miracle turbo. It will still be laggier than a 30R... and more responsive than a 40R
Which to me brings up: Where is the GT3076 HTA?
For those of us who want killer spool, wide power band, and "only" 380awhp peak on pump from 2 liters.
HTA is only available on the GT35, right?
Wrong.
HKS pictures show an HTA compressor on their GT3037S. And guess what, their housing says GARRETT on it. FP housing doesn't say. HKS even shows a version of the GT28 with an HTA compressor.
Anybody know what's going on behind all this?
Anybody know why FP can't get HTA GT3076 but HK$ can?
Gary
Old Dec 31, 2007 | 11:16 PM
  #39
discopotato03's Avatar
HKS's GT3037 series turbos use Garrett cartridges and compressor housings . If you check those turbo ID tags you'll find 3037 cartridges are 700177 series and the dash numbers ie 700177-5007 tell you the compressor trim size . -7 is 56T , -6 is 52T and unconfirmed but logical to assume -5 is 48T .
The "37" part of 3037 tells you that they use a GT37 series compressor meaning 76.2mm OD BCI-18 series wheels .
Where some confusion exist is when Garrett have used T04S compressors on the front of a GT30 turbine equipt cartridge . The old "S" wheels are 7/14 bladed and not the most modern design - from memory 1976 era things .
I think Garrett are more likely to fit a newer C117 series compressor if anything rather that a foreign branded wheel .
BTW I believe Garrett Japan make most of the GT BB range and HKS had them do a few model specific versions (slightly different wheel/trim options) for them .
Let us know the cartridge numbers of any you can't identify as I can reference most of them inc the HKS ones .
Cheers and happy new year , Adrian .
PS Finally seeing the light and considering an Evo 6 .
Old Jan 1, 2008 | 07:03 PM
  #40
Talonboost's Avatar
Thanks for the info Adrian. Sending a PM.
Old Jan 2, 2008 | 10:44 AM
  #41
evolved83's Avatar
goodluck with the kit. By the way does your car have tinted windows all around? I may have seen you
Old Jan 2, 2008 | 10:58 AM
  #42
CoachG's Avatar
I thought that I had read that somewhere along the way. It will be interesting to (eventually) see if/what the difference is between the two turbos (twin scroll T3 HTA vs. twin scroll T4 F1).
As Full Race is currently selling both (based on the info posted here), I would love to see them do some testing to determine the plus/minus of each setup. Maybe offer tseitz123 a discount on part of his kit so that they can use his test/tune info in their advertising???
Very cool situation that will (in time) benefit all of those Evo owners who are considering this type of turbo setup.
Old Jan 2, 2008 | 11:28 AM
  #43
I don't know enough about turbos to give a firm answer, but the inlet to the turbine housing is significantly larger on the T4 (and although both turbine exits are 3") so the question is how much more will the T4 flow?
Old Jan 2, 2008 | 12:21 PM
  #44
CoachG's Avatar
And how difference in housing size and flow will effect spool up/resposiveness of the turbo.
Very interesting indeed.
SloEvo12
Mar 28, 2016 02:03 AM
triple L
Nov 28, 2015 11:37 PM
EvolutionIXMR06
21
Jul 2, 2015 06:00 PM
S13 Curtis
Apr 11, 2011 11:08 PM
AutoMotoSports
Automotosports - Illinois
15
Apr 13, 2008 09:30 PM
