Help! Probs with shifter?What is it?!?
Old Dec 28, 2007 | 09:55 AM
ctbz860's Avatar
alright, here's the story... i went to visit my inlaws for christmas... just got back, my evo has been sitting for about 7 days, and now i'm having extreme problems moving my shifter. It was working perfectly fine before i left and now, it's very very hard to put it in gear.
When i get it into first gear, it starts off so crappy, second is okay, third feels fine, and then it feels like i can't get into fourth gear. 5th seems okay. I also have trouble moving to reverse.
Is it possible for the clutch or shift linkage to be frozen? I live in Connecticut. It has been snowing and pouring freezing rain here. Can that be a contributor to the problem also?
Damn, i'm stuck, and don't have any idea what to do. Any help will be appreciated.
Last edited by ctbz860; Dec 28, 2007 at 09:56 AM. Reason: checked off notification by email
Old Dec 28, 2007 | 09:57 AM
ctbz860's Avatar
i let it idle for 2 minutes before i tried to move my car
Old Dec 28, 2007 | 09:59 AM
smokedmustang's Avatar
It appears your car didn't want to go to the IN-LAWS either!!
jk. If you did NOTHING different, nor felt anything out of the ordinary prior to the trip, it could just be the weather. Let it warm up and see if it is still there. Leave it in a garage overnight. Keep us posted. How is your driving style? Mods? Clutch mileage?
Old Dec 28, 2007 | 10:00 AM
Check Brake/Clutch fluid?
Old Dec 28, 2007 | 10:02 AM
BlackIX's Avatar
I would check the shift cable end bushings, where they attach to the transmission linkage, under the hood first. They might be starting to sieze to the pin.
Old Dec 28, 2007 | 10:38 AM
ctbz860's Avatar
where exactly under the hood? is there a diagram on this site or another website where i can look this up? Thanks
Old Dec 28, 2007 | 10:41 AM
ctbz860's Avatar
brake/clutch fluid is in the same reservoir right? if so, the level is fine.
Old Dec 28, 2007 | 10:46 AM
RussellM's Avatar
Plat Vendor
Here's a diagram
Old Dec 28, 2007 | 01:56 PM
kingman4's Avatar
^ you're looking at #10 in the above. Shifter linkage bushing is behind the battery tray by the firewall. Mine seized up before. pb blaster + propane torch is magical.
Old Dec 28, 2007 | 05:37 PM
ctbz860's Avatar
Thanks very much, i spent about 2 hours trying to get my shiftin right... and i just finally got sick of it and jammed it in the stuck gears, it just sounded like i grinded the clutch a little, and now all is back to normal.
I guess i should've had someone i trusted drive it around for a bit everyday while i was gone on vacation.
I will be working on that number 10 in the diagram this weekend.
This site is awesome! The place to turn to when i need help! Thanks guys.
Old Dec 28, 2007 | 05:51 PM
Mitsutech56's Avatar
maybe some condensation in the cables freezing or the bushings at the ends.
Old Dec 28, 2007 | 05:57 PM
rush63's Avatar
It's under your battery tray.
Duh Panda
Mar 8, 2016 05:38 PM
digitaldrv
Lancer Troubleshooting
Nov 4, 2008 08:35 PM
EvolutionIXSE
18
Apr 18, 2007 01:43 PM
Shingen
Jun 22, 2006 07:37 AM
rcheung
Jun 8, 2006 04:08 PM
