View Poll Results: which combo would you rebuild with?
Eagle H-beam
33.33%
Manley H-beam
37.04%
Ross pistons
25.93%
Wiseco pistons
70.37%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
which would you choose....
Old Jan 2, 2008 | 09:50 AM
shivaswrath's Avatar
I'd personally go with JE Pistons and Pauter Rods, add that to your choices above. . .Eagle and Manley Rods are so so, and I wouldn't go with anything other than JE. . .maybe Wiseco. . .why? Previous experience in non-Evo car. . .
Old Jan 2, 2008 | 11:25 AM
TTP Engineering's Avatar
Originally Posted by deadbeatrec
well the vast majority of evom members whome have rebuilt their motors use wiseco/eagle. so thats what i went with. now i need bearings and a head gasket. im thinking clevite bearings and a stock head gasket.
We have cosworth rod bearings as well as 1.3mm and 1.5mm cosworth headgaskets ready to ship today.
They are more affordable than you think!
Old Jan 2, 2008 | 11:35 AM
SeanC's Avatar
Originally Posted by MR Turco
I truthfully really like JE pistons for the SR20, i am sure they make a set for 4g63 too. I know they are expensive but those special coated TTP pistons look like the ****.
+1
Old Jan 2, 2008 | 11:36 AM
deadbeatrec's Avatar
whats the stock head gasket thickness? i dont want to lower my compression any more.
Old Jan 2, 2008 | 12:31 PM
I believe stock is about 1.00-1.10mm.
Difference in compression is minimal and will in turn allow more boost to be run. Just think 1g DSM piston compression on the 4G63 was 7.8:1.
If you have purchased wiseco pistons, they are off the shelf at 9.0:1, whereas stock is 8.5:1. So effectively you end up with similar if not slightly greater compression than stock with the 1.3mm headgasket and 9.0:1 piston compression.
Old Jan 2, 2008 | 12:37 PM
if im not mistaken, stock is 8.8:1
Old Jan 2, 2008 | 12:43 PM
1g 4g63 7.8:1 90-94
2g 4g63 8.5:1 95-98
Evo 4g63 8.8:1 01-06 VII-IX
Old Jan 2, 2008 | 01:11 PM
StevenStarke's Avatar
eagles because of lightweight and strength as long as your tune is good.
Wisecos because they've always worked for me and perform great!!
-Steve
safat_evo
May 19, 2013 11:21 AM
rcheung
May 23, 2012 05:18 PM
EvolutinIX
124
Nov 8, 2010 04:37 PM
DynoFlash
48
May 16, 2008 09:55 AM
Mongo
11
Jul 24, 2007 10:19 AM
