My catch can results...
Old Jan 2, 2008 | 09:18 AM
urslo4n8's Avatar
After changin the oil last weekend i was actually surprised to see the amount of oil the catch can actually caught. I was a little bit sceptical putting it in and it actually doing something. It was definetly a bit over a 2liter bottle cap full. For anyone out there considering doing this mod its a great idea. Just my 2 cents...i know the guys out there that are running one know this already so dont be hatin.
Old Jan 2, 2008 | 09:22 AM
incandescent's Avatar
Post up a picture of your engine bay with the catch can. I want to do this mod and am intersted in ideas for placement.
Also, isn't there two places blow by oil can be caught? If you know then what are they? Im on LI too
Old Jan 2, 2008 | 02:49 PM
Robevo RS's Avatar
sorry for my english but if i'm right do you collect over 2liter oil in the catch can?
And you have a 9 so less then 2 years old?
Old Jan 2, 2008 | 02:52 PM
edardnaekim's Avatar
2 liter bottle CAP
Old Jan 2, 2008 | 02:54 PM
Robevo RS's Avatar
oh oke , sorry . I just was like, what a f)(ck , you must be connected to the oil line somewhere...
Sorry!
Ph3n1x's Avatar
The PCV Side catches alot of Blow By, but the Crank case Vent doesn;t get ****.
Old Jan 2, 2008 | 02:55 PM
mdsevo06's Avatar
He said Cap Full. As long as there's some kind of baffle, should do the trick.
Old Jan 2, 2008 | 02:58 PM
word, DC3 has a nice kit
Old Jan 2, 2008 | 03:06 PM
cfdfireman1's Avatar
urslo4n8, what kind of can did you install?
Phenix_fyah, you might be surprised at what the right setup will catch.
Old Jan 2, 2008 | 03:21 PM
Ph3n1x's Avatar
Trsut me brah I know....
https://www.evolutionm.net/forums/sh...=catch+oil+dc3
Dammit lost the pics.,....
Old Jan 2, 2008 | 04:08 PM
MitsuJDM's Avatar
I use a fuel filter on my breather side. I usually change it every other oil change. I use clear hose so I can see when the oil starts getting through the filter.
I use a BIG truck fuel filter between my PCV and ITM. I'm going to start using clear tube on it and changing it every oil change. Fuel filter work well.
According to my calculations, I'll spend $7 every 10k miles in fuel filters vs. $100 or so catch can. Catch cans look better and work a little better, but bang/buck, fuel filters win. So even after 100k miles of using twin fuel filters, you only spent $70, as opposed to a $80-100 catch can. They work good for me, so I'm happy.
I do think a REAL catch can would work better for the PCV side, for it catches MUCH more oil, but on the breather side, I don't see a need for a catch can. $2-5 fuel filter works great. Ghetto, sure, but who cares? It works.......
Old Jan 2, 2008 | 05:40 PM
I see...
vent side gets a bit more if you're using meth.
Old Jan 2, 2008 | 08:03 PM
TonyG's Avatar
My catch cans started collecting water when the weather became cold. Its definitely not coolant, and compression is fine (175psi). I think it has something to do with the winter gasoline.
Old Jan 2, 2008 | 09:19 PM
bKevO's Avatar
weapon R looks like it fits snuggle.....
Old Jan 2, 2008 | 10:28 PM
urslo4n8's Avatar
AGP nice fit right by the passenger side motor mount. Polished looks puuuuurdy.
