what could be causing my P0234
Old Jan 2, 2008 | 12:38 PM
panem's Avatar
So i have my car threw the P0234 code(Turbocharger Wastegate System Malfunction) my WGA has a dent and when i pull on 3rd, 4th and 5th gear i hear a thud around 4k-5k and my car loses acceleration for a second and it'll accelerate again.it stop for a week and when i tried it pull on 3rd last night it happened again(it was a cold night) anyone know if thats the problem b/c i'm thinking of replacing it but i just want to make sure that my WGA is causing the problem
my MODS:
-Helix IC pipe
-Speed Element O2 housing
-Helix DP
-HKS drop-in filter
dent on my WGA
Old Jan 2, 2008 | 12:41 PM
TeStUdO's Avatar
I can't see the pic, but if your wastegate is dented, it is most likely malfunctioning and not allowing the wastegate to open properly.
Old Jan 2, 2008 | 03:01 PM
panem's Avatar
http://img.photobucket.com/albums/v6...m/IMG_0106.jpg
here's the direct link to the picture if you guys cant see the above from my first post
Old Jan 3, 2008 | 07:47 AM
tvor's Avatar
You could be hitting fuel or boost cut I have that same issue right now, minus the dent in the WGA....probably because I am untuned at the moment and waiting on that. Too much boost past 5k.
Old Jan 3, 2008 | 12:46 PM
03VIII's Avatar
Yeah me too, right after my cam install. Mine came up as Overboost, tried turning down the boost but it still came back on. So I definately need a tune.
Old Jan 17, 2008 | 10:21 PM
panem's Avatar
so i just need a tune then. i c.
Old Jan 17, 2008 | 11:20 PM
Jameson_IXMR's Avatar
nonoo, change that wastegate at some point... Im not promising that is the problem causing the code, but it could lead to a bad problem.
bnice01
91
Apr 29, 2014 06:37 AM
landis
May 1, 2012 05:23 AM
Evostacio
Dec 12, 2011 10:13 AM
panem
For Sale - Part Outs
Mar 5, 2011 10:17 PM
boostfr3ak
10
Sep 5, 2010 11:35 AM
