clutch question, probably pretty stupid one too...
Old Jan 3, 2008 | 06:25 AM
ohEVO18's Avatar
The stock clutch is FINALLY going out after 80k, and I am not in the best financial spot at the time being and am wondering if a clutch for an 06 5spd will work for my 03 5spd, as I can get a used clutch in my price-range to work FOR THE TIME BEING until I can get my Exedy...
Thanks in advance
Old Jan 3, 2008 | 06:37 AM
KevinD's Avatar
same clutch, it will work. just curious though, labor is usually the most expensive part of the job, unless you're doing it yourself. you might want to consider at least buying a NEW clutch plate, and having the flywheel resurfaced (35 dollars at o'reillys). stock clutch plates are pretty cheap... 101 dollars from mitsubishiparts.net, you can also pick up a new pressure plate for 122 dollars, and a new throw out bearing for 43. so for 301 dollars you can have a new clutch assembly and a resurfaced flywheel..... if cost is that much of an issue, just buy the new clutch plate.
Old Jan 3, 2008 | 07:04 AM
flyingwangwang's Avatar
^^^ awesome advice!
Old Jan 3, 2008 | 07:05 AM
E VOL IX's Avatar
Yo man i have a ACT streetlite flywheel that i can machine for you... if u can get a disk and a presure plate..
Old Jan 3, 2008 | 07:53 AM
ohEVO18's Avatar
thanks for the advice...i need to do somethin though. I have to drive it like a bish cuz it slips in almost every friggin gear now...chalk one more up in the "L" column for me haha
Old Jan 3, 2008 | 07:54 AM
E VOL IX's Avatar
damn you better hurry... if she is slippin in every gear you bout to get left on the side of the road brother
Old Jan 4, 2008 | 04:49 PM
RussellM's Avatar
Plat Vendor
Here is a link for the OE stuff if you need any of it. Disc, Plate and Bearing all included in link below.
http://www.mitsubishiparts.net/cart/...4A019+MR145619
silverguy
27
Nov 5, 2010 01:10 PM
Evo9-MR
Oct 31, 2009 12:10 AM
Redline06
56
Oct 21, 2009 11:59 AM
mmartahus
Lancer Tranny/Drivetrain Tech
16
May 14, 2008 08:21 AM
Guerillah
Sep 26, 2006 06:14 PM
