MBC Installation Procedure
Old Feb 20, 2011 | 10:48 AM
  #46
brandnewman's Avatar
Nice write up. Subscribed for sure.
Old Feb 20, 2011 | 04:57 PM
  #47
flipjt22's Avatar
Great write-up, thanks for the reference.
Old Jun 15, 2011 | 01:19 PM
  #48
llDemonll's Avatar
Installed my MBC last night using Option 1, was replacing intake anyways so it was all convenient.
For those afraid of doing it without lifting the car fearing it will be too much work:
It's not. It takes a bit longer, but you have a lot more room to work with.
For Option 1:
These are the lines you are concerned about (granted I took the picture after I pulled them off the boost solenoid):
The left pipe is the upper intercooler pipe right behind the radiator
pull them off the boost solenoid and then cap the two fittings you pulled them off of (no pictures of the solenoid with caps on it)
the shorter line connects to the intake tube (charge tube?), the longer one continue to the turbo and wastegate. There is a 'T' in the line so it's easy to tell where both of them go and what the correct lines are to pull. the left line connects to the wastegate, i had just pulled it off before i took the picture.
Connect your new vacuum line to the turbo and wastegate, turbo -> boost controller in and boost controller out -> wastegate is how it will end up
Old Mar 2, 2012 | 06:23 PM
  #49
Evo9sanjose's Avatar
Exclamation
Went with option 1. Did not cap both lines
To the selenoid. Capped one and left the return to
Intake attached. I start loosing boost at 3k with
Some stuttering involved. Would skipping this step
Cause this problem. Or is it something else
Old Apr 29, 2013 | 11:08 PM
  #50
12WWGSR91's Avatar
great refrence, i just hope i went with the right path, going with option 1 and seeing how it goes
Old Oct 23, 2016 | 03:20 PM
  #51
2rbolag's Avatar
Do you cap the nipple on the turbo if using wg for boost source?
Old Oct 24, 2016 | 09:09 AM
  #52
llDemonll's Avatar
you can't use the WG for the boost source
Old Oct 24, 2016 | 01:03 PM
  #53
2rbolag's Avatar
Sorry, meant to say the dv/im T
Old Oct 25, 2016 | 07:50 AM
  #54
llDemonll's Avatar
in that case yes, cap the nipple on the turbo
make sure it's securely capped and zip tie the sucked on there with some good quality ties. the nipple still sees full boost and will pop a cap off if it's just pushed on and not secured
fostytou
359
Oct 23, 2025 09:54 AM
Raceghost
Mar 11, 2019 01:04 PM
pcguru2000
Aug 3, 2017 05:31 PM
Ckeesee12
Jul 28, 2017 09:23 AM
High_PSI
119
Oct 4, 2016 08:20 AM
