Problem with injectors
Old Jan 6, 2008 | 01:52 PM
Felginator's Avatar
I tried installing my Precision 880 injectors today, everything went smooth unit the point where I had to put the clips back on the new injectors, andthey won't go on. The tabs on the fuel rail are in the way now. Did I forget or miss something here? Hopefully this is a dumb mistake and an easy fix.
Here are some pics of the problem:
Old Jan 6, 2008 | 02:20 PM
RazorLab's Avatar
put the harness connections on first. The tabs are there to keep the connections on in case the metal clip comes out.
Old Jan 6, 2008 | 03:25 PM
MRJEVO's Avatar
You could grind the tabs off.
Old Jan 6, 2008 | 04:34 PM
Felginator's Avatar
Easy enough, off to do that now
Old Jan 6, 2008 | 04:35 PM
steadly2004's Avatar
I'd say option 1 is much better than option 2
Old Jan 6, 2008 | 05:20 PM
20Grockit's Avatar
+1 on option 1
Old Jan 6, 2008 | 05:30 PM
Felginator's Avatar
Option 1 worked fine, thanks guys.
Old Jan 6, 2008 | 05:36 PM
20Grockit's Avatar
ok good to hear.
RalliartCol
20
Aug 23, 2011 06:42 PM
Gonzo0991
Dec 20, 2006 06:13 PM
wj4
Oct 24, 2006 11:10 AM
kmcconn9
Oct 7, 2006 06:21 AM
