bad spark plugs??
Old Jan 19, 2008 | 10:43 PM
omniprobe's Avatar
bad spark plugs??
I am getting some fuel cut at high loads in the 5k+rpm range. It is also very cold (negative windchill) so maybe its the tune?
Old Jan 19, 2008 | 11:22 PM
hanahawaiian's Avatar
what ur mods? and u have aftermarket 02 housing? beacsue most Aftermarket o2 will cut off fuel and have grind wastegate hole inside.. it happend to me so i grind little bigger and finally it gone,
it dont cause by bad spark.. it can by Lean or Rich fuel.. what ur A/F ratio read?
Old Jan 19, 2008 | 11:30 PM
bluebanana23's Avatar
I just lost 10 IQ points from reading your post. Anyways, you could also get fuel cut from overboosting due to boost rising the cooler it gets. How much are boost are you reading from the gauge?
Old Jan 19, 2008 | 11:34 PM
SixOneNine's Avatar
LOL
Are you sure you're not mistaking fuel cut with sputtering? You can't just have "some" fuel cut. Check plugs first.
Old Jan 19, 2008 | 11:46 PM
tripperfx3's Avatar
10 bucks says its boost cut! Seriously. Are you tuned? If not than its boost cut due to denser air from the temp. Just get a MBC and turn it down or get tuned.
Old Jan 20, 2008 | 12:29 AM
Im running 25psi.. and cams are installed today in morning...
tuned by Famous NW Lucas English.. who Tuned paul evo 8 1000whp in Dsport mag in dec
Old Jan 20, 2008 | 12:33 AM
evovin's Avatar
Too much boost
Old Jan 20, 2008 | 08:06 AM
omniprobe's Avatar
It was late :P. Anyways I meant sputtering or felt like it was misfiring not fuel cut.
Mods 2.3 61mm aem ems.
I think it was most likely overboosting, I was trying to keep my eyes on the road and not on my boost gauge but I'll double check today.
It doesn't happen at low loads but if I floor it above 5k i getting sputtering.
Old Jan 20, 2008 | 02:38 PM
omniprobe's Avatar
OK no overboosting just stumbling at anything above 5.5k rpm with full throttle. So I am really leaning towards spark plugs now.
Old Jan 20, 2008 | 06:46 PM
sllt1776's Avatar
I would check the plugs as it is easy. Boost cut feels like hitting a wall, well maybe not so drastic but it scared me the first time i had it happen. i would think sputtering is ignition related, could be fuel delivery too but the plugs are an easy check.
Old Jan 20, 2008 | 07:18 PM
C6C6CH3vo's Avatar
High load fuel cut (boost-whatever cut) will feel like the engine just engulfed a bucket of jello, it will surprise you kinda like blowing off ducts will. Maybe it's just missing a little with the colder charge
DSMolition
Dec 5, 2014 03:16 PM
MacMan
18
Nov 28, 2014 10:51 AM
SrBlacksheep
For Sale - Part Outs
16
Aug 13, 2013 04:35 PM
wannaevo
Mar 12, 2006 02:10 PM
