mis shifting ( help plz)
Old Jan 21, 2008 | 12:16 AM
haseeb's Avatar
im having bad mis shifting ,mostly when goin from 1st to 2nd ..
my gears r hard also .
ive got a new clutch hks gd max .
which gear oil do u guyz recomend ?
also tell me wat shud be causing the mis shifting problem .
thanx
Old Jan 21, 2008 | 12:18 AM
JordanS4's Avatar
adjust the clutch pedal. it's probably not fully disengaging if this is a new clutch and you are just breaking it in. there could be a ton of other issues but this is usually the case with a new clutch.
as far as gear oil goes, OEM Diaqueen or Super Diaqueen works good for street driving. Lightweight Shockproof if it sees any type of racing action.
Old Jan 21, 2008 | 12:35 AM
haseeb's Avatar
the reak in has been finished .
its usually mis shifts when im racing .
daiqueen not available in my country .
mobil is available ,wat do u say about mobil ?
cud it be my shifter bushing ?
Old Jan 21, 2008 | 12:37 AM
haseeb's Avatar
the break in has been finished .
Old Jan 21, 2008 | 02:32 AM
Billy@EnglishRacing's Avatar
when is the last time your tranny fluid was changed?
Old Jan 21, 2008 | 02:51 AM
haseeb's Avatar
its has been a long time .around 1.5 year ago and 10000 miles
Old Jan 21, 2008 | 02:53 AM
start by flushing it and using Diaqueen, if that doesn't work then it is time time consider some of the other options
Old Jan 21, 2008 | 01:28 PM
dxbevo9's Avatar
haseeb i have had simmillar problems..i did three things that helped and is working nicely everysince.
1- went to exedy twin
2- replaced the front "lower" motor mount to agency power
3- installed an Ingalls stiffy engine torque dampner
eversince then i have not mis-shifted once!
bought all the parts from greg at GSC (stikiller.com) tell him moosa sent you and he'll take good care of you.
goodluck
Old Jan 22, 2008 | 01:37 AM
haseeb's Avatar
thanx buddy .
ill change my oil 1st .
lets see if it helps me out .
Old Jan 22, 2008 | 01:38 AM
haseeb's Avatar
hey moose ,plz tell me that is there diaqueen available in dubaie ?cause i often visit dubaie .
Old Jan 22, 2008 | 02:15 AM
dxbevo9's Avatar
haseeb..there isnt diaqueen available here either...however...the agency uses someother oil that is exactly equivilant to diaqueen..i cant seem to remember the name...Sam at 1000dunes stocks that oil...let me know next time you are here we'll catch up for coffee with afnan!
dragon831
Nov 12, 2012 08:02 AM
jnick
Lancer Tranny/Drivetrain Tech
Jul 2, 2011 12:46 AM
awdftw
Nov 5, 2009 11:31 AM
neonsalamander
48
Dec 29, 2004 04:23 PM
M3lachsilber
May 15, 2003 12:40 AM
