Clutch Disengaging issue.
Old Jan 24, 2008 | 02:24 PM
Evoryder's Avatar
Originally Posted by wkehn
I've had the same issue since I tossed in a new Exedy twin and brand new Shep rebuild last year. See this thread.
I also replaced the slave, it got better but still not great. The symptoms seem to be very sporadic for me.
I'm convinced there are very bad batches of Exedy twins out there in cars.
My exedy has 40,000 miles on it. THis just started happening 3 weeks ago.
Originally Posted by my04s2k
that sucks man, sorry it did not work out..... i am in the same boat probably. keep me posted.
I drove to work and it drove pretty decent, HOWEVER, i still can't down shift...symptoms are still there.
c
Originally Posted by letitroll
Hope you get this situated
Me to.
Old Jan 26, 2008 | 12:46 PM
4WS Tuning's Avatar
i was having some wierd problems...
the fact you say it works fine for a fine leads me to think it just needs more bleeding... or one of the connections to the clutch line is leaking so youre getitng air int he line...
when you go back and bleed are you seeing any air in the line after the fact?
Check the bolt that connects the clutch line to the slave, i bet tht crush washer needs replacing and is leaking.. That would cause it to work fine, then not..
If it was your tob, upshifts would be just as bad as downshifts and youd hear all kinds of funny sounds.
Good luck Jeff
Old Jan 26, 2008 | 04:23 PM
Evoryder's Avatar
Good luck Jeff
Good point on the TOB it would be making some god awful sounds...
Yes there is air in the system... a little. It's definitely a force or pressure issue. I have it a mitsu dealer ship and they are looking at it. Hopefully find exactly where it's letting air in.
The Slave comes with a new bolt, washers and bleeder.
Old Jan 26, 2008 | 04:24 PM
Evoryder's Avatar
clutch line that has the crush washer has not been changed.
Old Jan 26, 2008 | 04:38 PM
cfdfireman1's Avatar
Forget the speed bleeders they leak around the threads. The brake, clutch combination reservoir can be deceptive it will look like it's full but it can be low in the back chamber that feeds the clutch you need to over fill it and keep it there during clutch bleeding. The old fashion way is your best choice make sure you never release the clutch when the bleeder is open. If there was a leak in the line that was letting in air you would see fluid leaking out.
Old Jan 26, 2008 | 04:55 PM
Evoryder's Avatar
i made sure of keeping it at the neck while bleeding the system.
Old Jan 26, 2008 | 05:32 PM
Max Power's Avatar
I'm definitely interested in hearing your result - I'm having some dragging issues with my HD as well. On occasion it feels like there are 2 different engagement points. The first is right off the floor and the car will start rolling forward but if you apply more gas it will not really accelerate until you hit the second engagement point (which is where it normally engages). The weird thing is this is not a consistent problem - maybe once every 10 or so starts. I've bled and Motive bled the system along with adjusted the clutch pedal. I'm going to try bleeding it a bit more. Keep us posted.
Old Jan 26, 2008 | 10:30 PM
4WS Tuning's Avatar
thats your problem man... Everytime u unbolt a crush washer a new one needs to be put in there.. EVERY TIME.. i had the same issue when i put my ss line in too.. i didnt know better at the time either, im not a mechanic, i just do the basic stuff. all the local places sell them... I got some from pepboys they were a couple bucks for a pack of 6 i think.
Lemme know if you need some help, well bleed it for a good 20 minto make sure theres 0 chance of any air getting in there..
I also recommend raising the clutch to the highest setting that way ur pump the most amount of fluid as possible.
Cheers!
Old Jan 27, 2008 | 07:38 AM
Evoryder's Avatar
THese two here? or are you talking about like on the banjo bolts? Because both my sS lines and new Slave came with new washers.
Old Jan 27, 2008 | 07:51 AM
Evoryder's Avatar
or these two? Like i said earlier...got brand new ones from the slave.
Old Jan 27, 2008 | 08:21 AM
andrewzaragoza's Avatar
yeah i bet u have a very very small leak. other that the crush washer you may want to make sure your bleeder is tight enough.
Old Jan 27, 2008 | 09:14 AM
Evoryder's Avatar
yea will find it and fix it.
Old Jan 27, 2008 | 09:25 AM
03RRVIII's Avatar
have you tried adjusting the clutch pedal since you had the new clutch?
https://www.evolutionm.net/forums/sh...dal+adjustment
Old Jan 27, 2008 | 09:35 AM
4WS Tuning's Avatar
Yea he did all the basic bs...
I thought u said there's one crush washer u never swapped? Check there.. Wipe down every connection where it. Could leak the pump the clutch 30-50 times. Then wipe it down again. U should find some fluid somewhere. There's nothing else that could be ****ed up. You did everything except double check for leaks.
Old Jan 27, 2008 | 09:36 AM
Evoryder's Avatar
u kidding me? ...did u read my posts?
